2CarPros - Car Questions & Answers
1992 Cadillac Deville Repair Question
Topics covered: Cruise control, Body, No power.
Mileage: 135,000 miles.
Asked on September 19, 2012
1992 cadillac deville
Replied on October 31, 2012
Ok so I pulled the clip out and turned the car to the on position and the gray wire had 12 volts to it. So I pushed the harness back into the computer.
Tiny Response from sean03
160 questions asked
If the Orange light does not come on, you would need to remove the meter cluster to check the bulb and wiring.
Tiny Answered by KHLow2008 (expert)
39,827 answers provided
Ok I just did that funny thing happened. I tested the white and gray wire that would plug into the information center. I tested the two wires and their is no power going to those two. The two wires would be the ones that light up the cruise control light. If you test the white and gray wires together their is no power. If you test the white wire to the body of the car it has no voltage. If you test the gray to the body it comes up with 8.5 volts.
160 questions asked
How do I test the light bulb itself to see if it is good.
160 questions asked
Replied on November 1, 2012
find a power wire.run a jumper wire from a nown good power wire to the gray.does the lite go orange then.
Tiny Answered by cadieman (expert)
2,851 answers provided
