1992 Cadillac Deville Repair Question
Mileage: 135,000 miles.
1992 cadillac deville
what did do when u hit set button and the resume buttons
It just flashed to E.0.0 when I did it then it would switch back to E.7.0 real quick.
if the orange light isnt on the handle.you cant be getting voltage to the lever.is the lever new?
I went to the junk yard and got one that worked. They told me it worked. I also have the original. I switched it to the lever I got in the junkyard. But I switched it back to the old one that is the original.
if u are sure their is voltage to the pink wire test the other side of the connector if power is good on both sides of the connector and the orange light doesnt light when you turn the cruise switch on youll need to buy a good lever. gl
Which wires would I check for voltage color wise.
pop the lever connector out in your pics. and test the pink wire for voltage on both sides of the connector. with a test light then u will need to ck the ground next stick a paper clip in the connector on the pink wire then put the test lights clip to it.then probe the black wire at connector.if it lights the ground is good.start here all testing should be done with the key turned on and not started
Hey I got a multimeter. Do I need to buy a tast light instead. Thanks.
I seen you posted to me but I cant see what you put. So I am reposting the question. I got a multimeter. Do I need to buy a test light instead. Thanks.
key on test for voltage on the pink wire.put the neg.on the black wire and pos.on the pink does it have over 12volts on the meter?
