Replace the engine oil pan
ANONYMOUS
  • 2006 CHRYSLER PACIFICA
I need to replace the engine oil pan on my car. Does it just drop down or do I have to move other engine parts or have special tools?
Saturday, November 3rd, 2012 AT 8:38 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,959 POSTS
For this job you must drain the oil first, here is a guide
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Here is the guide from the manual with diagrams BELOW.
OIL PAN REMOVAL
1) Disconnect negative battery cable.
2) Remove radiator close out panel.
3) Remove radiator core support.
4) Remove radiator cooling fans.
5) Remove the engine oil indicator.
NOTE: It is not necessary to recover the refrigerant from the refrigerant system to perform this procedure.
6) Remove the top air conditioning compressor bolts.
7) Raise and support the vehicle.
8) Remove the lower air conditioning compressor mounting bolts and reposition the compressor with a suitable retaining strap.
9) Remove the air conditioning compressor bracket
10) Remove structural collar from oil pan and transmission housing.
11) Remove the inspection shield between the transmission and oil pan.
12) Drain engine oil.
13) Remove oil pan fasteners. Remove oil pan (Fig. 135).
NOTE: A small amount of oil will remain in the oil pan. Use care when removing the oil pan from the engine.
14) Remove oil pan gasket.
Cheers, Ken
Monday, May 22nd, 2017 AT 2:39 PM
PALO
  • 2005 CHRYSLER PACIFICA
  • 3.5L
  • 6 CYL
  • FWD
  • 120,000 MILES
Why do you have to remove so many other parts to remove the oil pan and can you remove the engine from the top or the front? I do not have a lift to raise the car off the front cradle to remove the sub frame.
Monday, May 22nd, 2017 AT 2:39 PM (Merged)
HMAC300
  • 48,601 POSTS
Engine has to be removed from bottom with cradle. Unfortunately vehicles are built for ease of assembly not repair.
JBOWEN
  • 2004 CHRYSLER PACIFICA
  • 6 CYL
What are the step by step procedures for oil pan replacement on a 04' Pacifica?
KHLOW2008
  • 41,815 POSTS
OIL PAN
REMOVAL
1. Disconnect negative battery cable.
2. Remove radiator close out panel.
3. Remove radiator core support.
4. Remove radiator cooling fans.
NOTE:
5. Remove the top air conditioning compressor bolts.
6. Raise and support the vehicle.
NOTE:
7. Remove the lower air conditioning compressor mounting bolts and reposition the compressor with a suitable retaining strap.
8. Remove the air conditioning compressor bracket
9. Remove structural collar from oil pan and transmission housing.
10. Remove the inspection shield between the transmission and oil pan.
11. Drain engine oil.
12. Remove the engine oil indicator tube.
13. Remove oil pan fasteners. Remove oil pan
1. Identifying Oil Pan
NOTE:
14. Remove oil pan gasket.
JBOWEN
Why is it necessary to do steps 2, 3, &4? I do not understand? Please advise. JBowen.
KHLOW2008
  • 41,815 POSTS
The above are from the shop manual. If it is not necessary, you can always skip them.
JOOLSSD
  • 0 POST
  • 105,000 MILES
What is involved in removing and replacing the engine oil pan?
I have an 05 Chrysler Pacifica with the 3.5 engine.
Thanks,
John
  • 108,269 POSTS
If I recall, there is enough room to remove it without lifting the engine.
IRISHFURBUSH
Thanks.
Saturday, June 13th, 2020 AT 8:44 AM
HAROLD DESAVAGE
  • 2007 CHRYSLER PACIFICA
  • 4.0L
  • 6 CYL
  • 100,000 MILES
Drain plug head is striped so bad that even a good bolt extractor will not get it out. Can the oil pan be dropped without lifting the motor? Or is there another way to remove drain plug?
Thanks,
Harold DeSavage
Thursday, June 18th, 2020 AT 10:46 AM (Merged)
HMAC300
  • 48,601 POSTS
You can drill and use a chisel to chip it out if you are good with drill and can go through center then it may bend what is left and come out. O;il pan is in two sections so you need to remove lower section also steering gear has to be removed and put out of way.
