Changing oil pressure sensor unit on Nothstar V8
LZ35MV
  • 2006 BUICK LUCERNE
  • 58,000 MILES
There is not enough room to get a hand in between the front frame cross member and engine area where oil filter is located (sensor is located above oil filter on engine block) in order to change the sensor. If you remove the front lower shroud assembly can you gain access by reaching over the front cross member or do you have to remove engine mounts and lift engine?
Friday, August 9th, 2013 AT 2:00 PM
HMAC300
  • 48,601 POSTS
Try taking the oil filter off to get to sensor you may have to remove a shield near there. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Saturday, August 10th, 2013 AT 8:28 AM
TIFFANY DANIELS
  • 4.6L
  • V8
  • FWD
  • 190,000 MILES
I am changing an oil pressure switch. What tools will I need to change the part in the car listed above it has a North star engine.
Wednesday, April 24th, 2019 AT 6:02 PM (Merged)
  • 31,937 POSTS
It will screw out, but as the switch is fairly deep you need a deep series socket to reach over the plastic plug, if the parts store selling the switch has tools, you may be able to purchase a socket to suite or get a wrench on it.
