Warming up engine
PAPET
  • 2014 DODGE CARAVAN
  • 3.6L
  • 6 CYL
  • FWD
  • 45,000 MILES
My co-workers keep telling me that I do not have to warm up the engine of my vehicle. They say that newer vehicles need not to be warmed up anymore. But my response is, if the vehicle have an oil heater it is possible. But if none, it needs to be warmed up especially during winter time. I live here in Canada and the temperature is really freezing during winter. Thank you very much and hoping for your most appreciated reply.
Monday, January 30th, 2017 AT 5:31 AM
HMAC300
  • 48,601 POSTS
Well you really do not have to warm the engine up. However, it depends on temperature as well. If you use regular oil and it gets down to minus twenty degrees F then you should warm a little while because oil gets like tar. If at zero degrees F you are pretty good to drive away or if in a garage as well.
Monday, January 30th, 2017 AT 6:57 AM
