Timing marks location
PEARLHICKORY
  • 2001 VOLKSWAGEN JETTA
  • 4 CYL
  • FWD
  • 158,000 MILES
Hey guys, I need the location of timing marks on my car listed above 2.0 SOHC. Timing belt went out and bent valves on number four piston. Replaced and have head ready to drop in, but I want to be 100% sure of proper timing mark locations. Thanks.
Saturday, April 30th, 2011 AT 11:41 PM
Here is a link to the information needed and a diagram below to help you find the camshaft timing marks:
https://www.2carpros.com/diagrams/volkswagen/jetta/2001
Cheers
Sunday, May 1st, 2011 AT 9:33 AM
LP69777
  • 4 CYL
  • MANUAL
  • 120,000 MILES
I had a mechanic take a look at it. He tells me the timing belt needs to be replaced plus the valves are probably damaged?
Are these two related and if so, do both need to be replace/fixed for car to run properly? My engine light is also on.
Tuesday, July 3rd, 2018 AT 2:36 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
If your vehicle is equipped with an interferrence engine and the timing belt is damaged/loose then this will cause valve damage as well. You will need both replaced or further damage will occur resulting in having to replace the engine or have it completely rebuilt. Need to have diagnostic trouble codes scanned to see why the engine code is illuminated.
Thanks for using 2CarPros. Com!
FLACO87
  • 4 CYL
  • FWD
  • MANUAL
How to fix the timing belt of car listed above, 1.8l turbo?
KHLOW2008
  • 41,814 POSTS
The site has just been upgraded and everything is different so I am still feeling my way around. I cannot find any way of posting diagrams so if you would let me have your email, I would send the replacement procedures to you.
NOWHATIMEANVERN
  • 4 CYL
  • FWD
  • 85,000 MILES
Customer brings car in they said the car shut off while driving. I looked at the car and determined that it was out of time by the sound it made while cranking engine. Is this engine a zero tolerance engine?
BLUELIGHTNIN6
  • 16,542 POSTS
Depends on the engine size. Most four cylinders with non-turbo eight valve are generally non-interference engines.
STEVEW84
  • 673 POSTS
Most European cars are interference engines. How out of time is it? Should probably do a compression test once you get it back in time.
DENNIS ORTENBURG
  • 4 CYL
  • MANUAL
  • 215 MILES
Broke timing belt when running.
  • 31,937 POSTS
This will be an interference engine you will have valve damage. This will require the removal of the cylinder head.
Mark (mhpautos)
