1994 Volkswagen Jetta car wont start
HANCOCK_JR
  • 1994 VOLKSWAGEN JETTA
  • 6 CYL
  • FWD
  • MANUAL
  • 157,656 MILES
Hey, I was messing with my deck wires and than when I turned my car on it would not start, everything works and it tries to turn over and everything but it wont start. I was told it might be some currency interference with my ignition system or something. What can it be and how can I repair it. Thanks for your help.
-JR
Saturday, September 11th, 2010 AT 7:39 PM
You probably shorted out a wire that goes to the ignition/fuel system and also the computer-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Tuesday, December 20th, 2016 AT 11:22 AM
