Check Engine Light will not scan with Te1 and E1 shorted by a jumper on the Data Link Connector.
I have followed the repair manual; battery has 12.58 volts and the ignition to on position. Placed jumper to short ort Te1 and E1 pints on the Data Link Connector. The Check Engine Light stays on solid without give me any flashing.
With no jumper on the Te1 to E1 pins, I follow the manual to do the Check Engine Light resetting by removed the 15A Radio fuse. However, this Light still stays on.
Only able to reset this Check Engine Light is to disconnect the battery and reconnect it back. Did I do something wrong in the procedure? What component has failed on me? Please help.
Jun 21, 2009 at 5:21 PM
