Blower motor
AUGGIEDOG44
  • 1999 TOYOTA COROLLA
  • 4 CYL
  • 134,500 MILES
How do you replace a blower motor?
Wednesday, December 8th, 2010 AT 8:38 PM
Here is a guide to help walk you through the steps and help test the blower motor to see if it is bad with diagrams below to show you how on your car.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Wednesday, December 8th, 2010 AT 9:30 PM
SIRRYCHE
  • 4 CYL
  • FWD
  • 75,000 MILES
Do you have to take out the dash to replace the heater blower motor?
Tuesday, August 27th, 2019 AT 1:33 PM (Merged)
  • 31,937 POSTS
Hi there,
No I believe that it will with draw from hearer box. Remove glove box and trim, look under heater box there are 3 (i think ) screws and the electrical loom, undo plug and screws and motor should come down
Have a close look as you undo it and don't force anything an I feel that it will come out.
Mark (mhpautos)
TIM ASKUE
1999 Toyota Corolla 115000 miles
How do I acess and replace a noisy blower motor?
  • 31,937 POSTS
Hi there,
you should be able to access the blower motor once you remove the glove box, it may just have leaf litter fouling the fan, this is fairly common problem.
Mark (mhpautos)
DFOLAN
  • 1998 TOYOTA COROLLA
Heater problem
1998 Toyota Corolla 4 cyl Two Wheel Drive Automatic
MY heater motor works fine, but the fan housing is broken and it needs replacement. How do I get to the fan to replace it? I assume I need to remove the dashboard, but have no idea on how to do that. Please advise.
Also, can you recommend a reliable, inexpensive vendors for quality replacement parts?
MMPRINCE4000
  • 8,548 POSTS
The best approach is to use the car repair link in this thread or get a Haynes manual. This is a complicated sequence of removal, so an actual step by step procedure would be best.
SUYOG_11
  • 4 CYL
  • 137,000 MILES
Hi, I am using a Corolla. My A.C. Fam makes noise when I start he FAN. Sometimes it works good.
I need some help to find out what that fan is called and how to replace it on my own.
Thanks.
MMPRINCE4000
  • 8,548 POSTS
There are two fans, disconnect power connector to fan (one at a time) to isolate which fan is making noise.
SUYOG_11
Thanks for the information below.
I would also like to know if I can find any video/diagram on number of screws I need to untight.
I tried getting fan off but I was not successful.
MMPRINCE4000
  • 8,548 POSTS
Cooling fan should have 4 bolts, one on each corner. AC fan will require removing the grill.
OUTDOORSMAN388
  • 1993 TOYOTA COROLLA
What is the proceder for changing a blower motor in a 93 corolla?
Follow below instructions
https://www.2carpros.com/forum/automotive_pictures/12900_1993_toy_corolla_blower_motor_removal_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_1993_toy_corolla_blower_motor2_1.jpg
www. .com
