HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Celica
Fuel System
Fuel Pump
Relay
Location
1991 Toyota Celica
KARONTE
MEMBER
1991 TOYOTA CELICA
Electrical problem
1991 Toyota Celica 4 cyl Two Wheel Drive Automatic
hi!
my cuestion is.
where is the fuel pump relay for celica '91
Tuesday, January 22nd, 2008 AT 5:03 PM
MECHANIC
The FP relay is on the fuse/relay block no.5 on right side of radiator.
Tuesday, January 29th, 2008 AT 4:12 AM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Relay Location Content
Fuel Pump Relay
Where Is Fuel Injection Relay On 1992 Toyota Celica? And, Does The Fuel Pump Relay On The Same Car Only Provide 12v To The Fuel Pump?...
Asked by
schserv
1 ANSWER
1992
TOYOTA CELICA
Fuel Pump Not Running
Fuel Pump Not Working, If I Jump The Test Connector It Will Work Checked For Power At The Circuit Opening Relay Fp Terminal Read 12v But...
Asked by
luvthyapril
1985
TOYOTA CELICA
No Power To Efi Relay Coil Or Fuel Pump
Ts A 93 Celica St With A Newly Swapped 5afe In Place Of The 4afe( Direct Swap).I Swapped The Engine But No Starting For Me. Never Thought It...
Asked by
wardandhiswagon
1 ANSWER
1993
TOYOTA CELICA
One Day It Stopped Running. It Cranks Over But Doesn...
Hi, I Have A Rear 1992 Toyota Celica Gt Convertible That Was Dealer Modified In 1992. One Day It Stopped Running. It Cranks Over But Dosent...
Asked by
JVLightning
6 IMAGES
1992
TOYOTA CELICA
1977 Toyota Celica No Fire To My In Tank Fuel Pump.
I Am Not Getting Any Fire To My Fuel Pump. Any Suggestions? Help? It Has Been Setting Up Several Years. Have Cleaned Tank And Replaced Fuel...
Asked by
willybgorilla
1977
TOYOTA CELICA
VIEW MORE
How to Use a Test Light
Fuel Pump Replacement
Car Cranking but Not Starting? Try This
