Serpentine Belt Replacement
IKEAND TINA
  • 2008 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 200,000 MILES
Can you get me a diagram of a serpentine belt for a 2008 toyota camry, 4 cyl?
Saturday, July 9th, 2011 AT 9:42 PM
Here is the instructions on how to replace the serpentine belt with a diagrams below.
REMOVAL
REMOVE FRONT WHEEL RH
REMOVE ENGINE UNDER COVER RH
REMOVE FRONT FENDER APRON SEAL RH
REMOVE V-RIBBED BELT
Using SST and 19 mm socket wrench, loosen the V-ribbed belt tensioner arm clockwise, then remove the V-ribbed belt.
SST 09216-42010
NOTE:Be sure to connect SST and the tools so that they are in line during use.
When retracting the tensioner, turn it clockwise slowly for 3 seconds or more. Do not apply force rapidly.
After the tensioner is fully retracted, do not apply force any more than necessary.
Saturday, July 9th, 2011 AT 10:51 PM
IDAMAE88
  • 2005 TOYOTA CAMRY
2005 Toyota Camry 4 cyl
I changed my alternater by myself, but now can not get the serpentine belt back in. I need a diagram of the serpentine belt for the 2005 camry. I know the hood usually has it on there, but it isnt on there for some reason. I would love the help!
Tuesday, July 21st, 2020 AT 11:25 AM (Merged)
STEVEW84
  • 673 POSTS
https://www.2carpros.com/forum/automotive_pictures/170495_belt_1.gif
Don't know how good the picture will show up. It kind of reminds me of an hour glass.
DON2CARPROS
  • 2005 TOYOTA CAMRY
  • 6 CYL
  • 27,000 MILES
27,000 miles 5 1/2 ownership.
Drive belts are working should they be replaced for peace of mind and what is a good price?
MMPRINCE4000
  • 8,548 POSTS
Inspect them every 6 months for cracks, excessive wear, otherwise they are OK.
CHICAGO68
  • 2004 TOYOTA CAMRY
  • 130,000 MILES
Changing alternator belt. Found matrix on how to place belt around pulleys. Not able to get belt around alternator pulley (last pulley needed to finish.) Tried to move car into garage for the night but now cannot move gears into neutral to push car. They are locked. What can I do?
Tuesday, July 21st, 2020 AT 11:26 AM (Merged)
RIVERMIKERAT
  • 6,110 POSTS
Check to see what tool was dropped and remove it.
KHLOW2008
  • 41,814 POSTS
You can either use the manual option to disengage the gear shift interlock system to enable you to shift to neutral.
Reinstall the battery, if it had been disconnected, and turn ignition switch on and depress the brake pedal to disengage the interlock system.
If battery is not disconnected and turning the ignition switch on while depressing the brake pedal does not allow you to disengage the interlock, check for a blown fuse.
SOUTHERNGQ
  • 8 POSTS
  • 2004 TOYOTA CAMRY
  • 4 CYL
  • MANUAL
  • 81,000 MILES
I have a 2004 Toyota Camry LE. Recently I went to get my tires rotated and balanced and asked the service center to change my Serpentine Belt while they were doing it. The technician started to work with the belt and could not get the other one off. There is a bolt on the housing that has a very unique head. They did not have a tool in the whole shop that would fit this bolt.
Can a tool be purchased that will fit this head? If not, is there an adapter that can be purchased to make an existing tool work?
I just find it hard to beleive that the dealership is the ONLY place I can get my belt changed. Any advise would be appreciated.
F4I_GUY
  • 3,302 POSTS
Take it to another shop, clearly this shop does not have appropriate tools. The tensioner uses a 19mm head, so any 19mm wrench or shallow socket will do.
SOUTHERNGQ
  • 8 POSTS
The bolt, or screw in question does not have a standard or metric head. It is an odd shaped head that I have never seen before. See the attached photo. I hope you can see it.
https://www.2carpros.com/forum/automotive_pictures/76834_cid__0823091639a_2.jpg
WIL3327
  • 2004 TOYOTA CAMRY
  • 17,500 MILES
I WOULD LIKE TO CHANGE THE SERPENTINE BELT OR DRIVE BELT, BUT I NEED ILUSTRATED INSTRUTIONS IF PDF TYPE
HMAC300
  • 48,601 POSTS
Here it is. Just loosend the tensioner and remove belt, reverse for install.
WIL3327
Excellent work.I have saved your website in my favorites menu. From now on when I need help with anything to do with my camry, be sure I will turn to your website for help
thank you very much
HMAC300
  • 48,601 POSTS
Just make sure to give all the details, like engine size, manual or automatic trans.
Tuesday, July 21st, 2020 AT 11:27 AM (Merged)
JOYC
  • 2004 TOYOTA CAMRY
We had to replace the alternator on our Camry and now the serpentine belt want stay on the pulleys. Do you know why?
  • 108,300 POSTS
Is the new alt a direct fit part? Is everything tight and the belt routed properly? Have you checked to make sure the belt tensioner is good and keeping the belt tight?
MIKELAC
  • 2004 TOYOTA CAMRY
2004 Toyota Camry 4 cyl Front Wheel Drive Automatic
how to change the serpentine belt
KHLOW2008
  • 41,814 POSTS
Hi mikelac,
The Automatic Belt Tensioner Pulley arm has a hex head where you can turn to release the tension and remove the belt.
https://www.2carpros.com/forum/automotive_pictures/192750_SerpentineCamry04_1.jpg
MIKELAC
Thank you so much I just was not sure. And it is so close it there thanks again mike.
