Low power engine
CAMCAM
  • 2002 TOYOTA CAMRY
  • 4 CYL
  • 135,000 MILES
We have a 2002 Toyota Camry, the problem that we're having is when the car is cruzing at 55 to 60 miles per hour the car boggs down an doesn't allow you to go any faster. Now we would like to keep up with the traffic. We have taken it to the mechanic which he checked the computer, both 02 sensors, checked the catylitic converters, spark plugs, changed serpentine belt and we're still having an excelleration problem. The mechanic stated after cleaning the throttle body, that the problem could be the excellerator peddle sensor. We need your help now, Please!
Friday, November 20th, 2009 AT 8:22 AM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Friday, November 20th, 2009 AT 1:36 PM
LAVYEDC
  • 2002 TOYOTA CAMRY
  • 4 CYL
  • 75,000 MILES
Engine Performance problem
2002 Toyota Camry 4 cyl Two Wheel Drive Automatic 75000 miles
second hand Toyota Camry 2002
I drive in the city around 25 mile/hour and the engine use more gasoline, what happen?
Saturday, September 23rd, 2017 AT 12:15 PM (Merged)
  • 31,937 POSTS
Just start with a full tune, scan and comp test, see if that shows any problems.
Mark (mhpautos)
GADAMART
  • 2002 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 72,000 MILES
2002 Toyota Camry 4 cyl Front Wheel Drive Automatic 72000 miles, it has no check engine lite on
the car start good then after warmsup it begins to shake a little then stops.I would appreciate if could give me an idea what could be wrong with it. I thank you.
Inspect and test the air flow meter and throttle position sensor.
Saturday, September 23rd, 2017 AT 12:16 PM (Merged)
