2001 Toyota Camry Leak
ED 1
  • 2001 TOYOTA CAMRY
  • 4 CYL
  • 51,000 MILES
I have a very slight leak coming from the hose under the car, past the engine. It drops what looks like to be water. It only drops a couple of drops in a 24 hour period.
Not to be cheap, but I would like to see if you can asnswer my question before I donate.
Friday, August 20th, 2010 AT 1:53 PM
BDOGG0070
  • 42 POSTS
If it is clear like water that could be condensation from the a/c if it is the color of the antifreeze then you may have a weak clamp or clamp not tight enough or possibly not positioned right
Friday, August 20th, 2010 AT 1:56 PM
