2000 Toyota Camry not start
PRHYER
  • 2000 TOYOTA CAMRY
  • 6 CYL
  • 75,000 MILES
Alarm wen off after unlocking door. It was hard to stop and think just ran out of time to stop
Now engine not turn over, nothing happens, have tried both keys no luck have not had or used remote for several years and both have been lost.
any way to reset this no start problem?
thank you
Pat Hyer
Sunday, January 20th, 2008 AT 12:36 PM
MASTERTECHTIM
  • 4,750 POSTS
Unlock the passenger side door with the key. You probably have a problem with the drivers side door unlock switch on the latch that tells the alrarm it is being unlocked with the key. If that switch is bad your alarm module will only see the trigger from the door being opened without seeing it being unlocked and thinks someone is breaking in. Hope this helps and remember feedback and votes for me are greatly appreciated. ***Oh yeah if your vehicle has an aftermarket alarm system it works differently. Look under the drivers side of dash with a flashlight and you will see a push button and or a switch. While holding in the button crank your engine, this will over ride the alarm.
Sunday, January 20th, 2008 AT 12:48 PM
