1999 Toyota 4Runner
MERVILLB2002
  • 1999 TOYOTA 4RUNNER
Engine Cooling problem
1999 Toyota 4Runner 6 cyl Four Wheel Drive Automatic
obd 11 code P0125 keep coming up. Even when I clear it. What do I look for to fix the problem.
Sunday, November 30th, 2008 AT 8:49 AM
ZACKMAN
  • 4,202 POSTS
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
This means that the engine coolant temperature (ECT) sensor indicates that the engine has not reached the required temperature level to enter closed-loop operation within a specified amount of time after starting the engine.
Symptoms
You will likely not notice any drivability problems.
Causes
A code P0125 may mean that one or more of the following has happened:
* Insufficient warm up time
* Low engine coolant level
* Leaking or stuck open thermostat
* Faulty coolant temperature sensor
Possible Solutions
The simplest thing to do is to reset the code and see if it comes back.
If the code comes back, the problem is likely going to be the result of the above causes (faulty thermostat, faulty coolant sensor, or a low coolant level).
Wednesday, December 3rd, 2008 AT 12:03 AM
