Seat belt replacement sensor
KJCOX
  • 1992 JEEP CHEROKEE
  • 133,000 MILES
When I change the driver side seat buckle do I have to plug in the sensor?
Wednesday, January 15th, 2020 AT 9:58 AM
Yes. Otherwise the seat belt light will remain on. If this doesn't bother you then you can leave it off but this is not advised.
Let me know if you have other questions. Thanks
Wednesday, January 15th, 2020 AT 5:12 PM
KJCOX
  • 133,000 MILES
Do I need to connect the seatbelt sensor when I change out the driver side buckle?
Tuesday, December 29th, 2020 AT 2:02 PM (Merged)
  • 52,797 POSTS
Good evening,
Is it currently disconnected? Is the light on for the airbag system? The simple answer is yes, it needs to be connected. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
