RPM needle is stuck beyond the 6 and won't fire
ST331
  • 1992 DODGE DAKOTA
  • 295,000 MILES
So I have a 3.9 v6 5 speed dodge dakota 295000 still strong was in the process. Of cleaning terminals when I hooked the battery back I noticed my rpm e needle behind the unleaded only I went to crank it and the motor turned over but no fire
Sunday, August 18th, 2013 AT 1:23 AM
DRCRANKNWRENCH
  • 3,380 POSTS
There may be a problem with the ignition system (hall sensor in the distributor etc). I am attaching a walk through diagnostic that covers all the most probable causes. Just use the link below;
.https://www.2carpros.com/articles/everything-goes-dead-when-engine-is-cranked
Sunday, August 18th, 2013 AT 3:02 AM
