Need the torque spec and sequence of the valve cover.
Sunday, August 11th, 2019 AT 11:50 AM
MECHANIC
Good afternoon,
You tighten the bolts from the center out. Do the center 3 bolts first, then the rear bolts and then the front.
The torque spec is attached.
Images (Click to make bigger)
SPONSORED LINKS
Sunday, August 11th, 2019 AT 12:25 PM
BRANDON RAGAN
MEMBER
Thanks for the help really appreciate it.
Sunday, August 11th, 2019 AT 8:15 PM
MECHANIC
You are welcome.
Always glad to help.
Sunday, August 11th, 2019 AT 10:46 PM
KENNETH TAYLOR
MEMBER
2012 CHEVROLET SONIC
1.4L
4 CYL
TURBO
2WD
AUTOMATIC
74,000 MILES
Vacuum leak from the valve cover. Got new valve cover on just need to torque the bolts. Need the torque specs on tightening the bolts. Thanks, in inch pounds please.
Saturday, March 13th, 2021 AT 6:03 PM
(Merged)
MECHANIC
Good afternoon, I attached the torque spec and the tightening sequence for your project. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
SPONSORED LINKS
(Merged)
STEVE W.
MECHANIC
Welcome to 2CarPros. From the spec sheet it looks like they want 71 lb. In. Pattern starts in the center and goes out.
(Merged)
MUNNEN
MEMBER
1 POST
I have a 1.8 L Chevy sonic LT 2012 I need to replace the valve cover gasket and I need to know what’s the torque sequence is also how many inch pounds do I tighten the screws? Thank you for your help by the way I did buy a Fel-Pro gasket
(Merged)
STEVE W.
MECHANIC
Welcome to 2CarPros. The 3 short screws are installed first, then the long screws. All are torqued to 71 inch pounds. There is no set pattern but a simple criss cross pattern starting in the middle should be good.
(Merged)
MECHANIC
Did you get the attachments both of us sent you for this repair?
(Merged)
RENé FOURIE GERTZEN
MEMBER
Good day, I have a Chevrolet Spark 1.2 (M300) and need torque specs of the valve cover bolts?
Wednesday, April 13th, 2022 AT 3:53 AM
SQM
MECHANIC
Since your question is on a different model vehicle, kindly open a new thread and ask the question. This will put it in front of all the experts.
