Serpentine belt replacement and diagrams please?
PONTIAC GTP
  • 2005 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 70,000 MILES
I have a 2005 pontica Grand AM V6. I just broke the belt and bought a new one, I have changed many belts before. For some reason this belt is giving me a hard time, It seems to need to be around the motor mount to go on the pullies. Do I have to remove the motor mount replace the belt? Or is there some way of threading it throught so I do not have to take the motor mount off? Please help Thank you
Monday, January 26th, 2009 AT 6:47 PM
ZACKMAN
  • 4,202 POSTS
You do have to remove the engine mount to replace the belt.
https://www.2carpros.com/forum/automotive_pictures/55316_04grandambelt1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_04grandambelt2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_04grandambelt3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_04grandambelt4_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_04grandambelt5_1.jpg
Tuesday, January 27th, 2009 AT 12:44 AM
PASTOR2
  • 6 CYL
  • FWD
  • 99,000 MILES
I can get the belt off the pulleys by relasing the tensioner, but cannot get belt up past what seems to be a motor mount. Must I remove this mount or is there some way to thread the belt off that I am not seeing?
Tuesday, July 28th, 2020 AT 12:56 PM (Merged)
MMPRINCE4000
  • 8,548 POSTS
If mount is inside the belt loop, then it must be removed.
https://www.2carpros.com/forum/automotive_pictures/108325_GA_belt_1.jpg
RMOORE09
  • 132 POSTS
  • 2004 PONTIAC GRAND AM
  • 165,000 MILES
Hello, I was wondering on how to change the serpentine belt on this car? I was told it involves an engine mount. It has the 3.4L V6 motor. What is the procedure of changing the belt on this car?
Thank you!
SATURNTECH9
  • 30,869 POSTS
Put a floor jack with a piece of wood under the oil pan then pop loose the top engine mounts out. Then you can jack the engine up to get clearance to change the belt. Then you have to release the belt tenisor while removing the belt and putting the new one on.
JDODGES
Engine Mechanical problem
2004 Pontiac Grand Am 6 cyl Two Wheel Drive Automatic
where can I get a serpentine belt routing diagram
Tuesday, July 28th, 2020 AT 12:58 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
This is the link for the serpentine belt routing diagrams
https://www.2carpros.com/diagrams/pontiac/grand-am/2004
RAY POLLOCK SR.
  • 2003 PONTIAC GRAND AM
  • 146,000 MILES
Belt broken need pattern for installation of new belt.
CARADIODOC
  • 33,755 POSTS
There should be a sticker on the engine or under the hood showing the routing. If you cannot find that, you will need to tell me which engine you have.
  • 2002 PONTIAC GRAND AM
  • 134,944 MILES
I have a 2002 pontiac grand am. A while back the serpentine belt started squeaking, but it wasn't very loud so I left it alone. Lately the belt is really loud and gets louder as I accelerate. I wanted to know if it can be fixed and for how much. I am in high school and work at a fast food resturant, so I don't have a lot of money, but I just want it fixed and to stop squeaking.
Tuesday, July 28th, 2020 AT 1:01 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
What size engine do you have?Sounds like a bad belt tenisor.
DJCL
  • 767 POSTS
Try spraying a small amount of water on the belt to see if the sound goes away. If it does try changing the belt.
SATURNTECH9
  • 30,869 POSTS
If its getting really loud its more then just a belt.
KELVINBEN
  • 7 POSTS
Could be water pump or the pulley that the serpertin belts on.
KELVINBEN
  • 7 POSTS
I got an 03 did the same loud as hell it was my waterpump
SILVERNBLAK
  • PONTIAC GRAND AM
2001 Pontiac Grand Am/ 3.4L V6/62000 miles. I bought a new accessory drive belt to replace old one. But to remove old belt, there is a heavy aluminum mounting type bracket bolted between the engine and the body that must be removed. Does the engine have to be supported to remove this bracket safely? Please help with info. Thanks. : :P
Tuesday, July 28th, 2020 AT 1:03 PM (Merged)
BOOTDOG
  • 665 POSTS
Yes you'll need to support the engine before removing the mount. Find a stable place underneath the car to support the engine. Don't use the oil pan for support. Good luck on your repairs
GREGORY HATELLA
  • 2001 PONTIAC GRAND AM
  • 6 CYL
  • 4WD
  • 10,500 MILES
I replaced the serpentine tensioner but I dont know how its suppose to sit
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_01GPv6_1.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_01GPv61_1.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_01GPv62_1.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_01GPv64_1.jpg
JAMESHILL1
  • 190,567 MILES
I have a serpentine belt that keeps slipping off just put on a new tensioner and can't find out why it keeps coming off help please I put the serpentine belt on "the right way " every time all lined up well
