Parking lights not working
EWOK19874
  • 2006 PONTIAC G6
  • 75,000 MILES
The rear park lights will not come on all of a sudden. The brake lights work, the turn signals work, and the reverse lights work. I have checked all the fuses, with none of them blown. I removed the headlight switch from the steering column, but I don't know which connections should be closed, and I need to know where to look next.
Do you
have the same problem?
Monday, June 18th, 2012 AT 10:26 PM
  • 52,797 POSTS
It could be the bulbs because the front and rear are tied together here are the wiring diagrams so you can see how it works. This guide can help as well.
https://www.2carpros.com/articles/no-tail-lights-exterior-running-lights-tail-lights-out
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Monday, June 18th, 2012 AT 11:00 PM
SHARIQ
Thank you for this post I had the running lights out had to get a new relay for $34.00 all fixed! I love this site.
Monday, July 1st, 2019 AT 4:04 PM
MMURAN02
  • 2005 PONTIAC G6
  • 6 CYL
  • FWD
  • 75,000 MILES
The tail lamp light was out so I changed the bulb. But the running light still wont work but the blinker works. I was wondering if it could be a fuse or anything else
Monday, July 1st, 2019 AT 4:05 PM (Merged)
SERVICE WRITER
  • 9,123 POSTS
Try wiggling the bulb in the connector to see if it will lite. Probably a socket or wiring issue not a fuse.
JOANNAWIGGINS
  • 2005 PONTIAC G6
  • 6 CYL
  • FWD
  • 84,000 MILES
My day time lights are working but back lights are not they only work when I press the brakes>> I changed fuses and bulbs worked for about 5 minutes then they went right back out. What next?
JDL
  • 16,098 POSTS
Were any fuses blown? There are lighting trouble codes, so you may have to get the B type codes checked, all codes. Voltage for the tail lamps comes from the park lamp relay. I'd have to check voltage and ground circuits at the relay, the relay itself may be ok. The BCM controls the ground for the coil side of relay. The bcm monitors sense circuits, one from the light sensor, the other from the headlamp switch. I can't tell you exactly where the problem is without testing?
MYBROWNS
  • 2006 PONTIAC G6
  • 6 CYL
  • 4WD
  • 31,000 MILES
My brake lights stay on if I tap the peddle a couple times they go out for a few seconds isnt there a switch on the inside underneath the peddle that might be sticking or am I wrong ps you must put your foot on the peddle to put it in gear
2CARPRO JACK
  • 11,533 POSTS
Yes, there is a brake switch and it sounds either sticky or misadjusted. You may have to remove the lower plastic shield to be able to see up to the switch, but it is there
