Oil pressure sending unit location
JAYARDITO
  • 1999 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 120,000 MILES
Where is the oil pressure sending unit located on a 1999 Pontiac Bonneville 3800 6 cyl. Where online could I find a picture of the engine area that I could view?
Thursday, January 27th, 2011 AT 3:52 AM
IMPALASS
  • 3,112 POSTS
Hello â€
Here is a couple of pics for you per your request depending on your engine. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Friday, January 28th, 2011 AT 2:13 AM
VICABS
  • 1997 PONTIAC BONNEVILLE
Engine Mechanical problem
1997 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
Where is the location of the oil pressure switch?
Tuesday, April 14th, 2020 AT 5:20 PM (Merged)
Its on lower right rear of engine behind camshaft position sensor see item location M
https://www.2carpros.com/forum/automotive_pictures/12900_ops_2.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_ops3_1.jpg
LARRY LEIBFRIED
  • 1996 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 15,000 MILES
I need to replace the oil pressure sending unit, where do I find it.
DRL56
  • 7 POSTS
Look in front of starter
