1992 Plymouth Laser
ALANSS454
  • 1992 PLYMOUTH LASER
Engine Performance problem
1992 Plymouth Laser 4 cyl Two Wheel Drive Manual
This car has a severe power loss.I have checked timing
marks, ok, checked exhaust, ok, turbo has plenty of boost,
no vac. Leaks. When you adjust the cam timing the idle is
way to high, when you back the timing off you lose power, the idle up solenoid doesn't seem to change the idle when unhooked or hooked up. When it is hooked up
the idle goes up and down until you unplug it. What am
I missing here?
thanks, Alan
Wednesday, September 1st, 2010 AT 9:44 AM
  • 108,192 POSTS
Are you refering to the idle air control valve? If bad, that will cause the idle to be eratic.
Wednesday, September 1st, 2010 AT 10:23 PM
ALANSS454
  • 7 POSTS
I understand it will create a problem with idle but why does the car have no power, that is my real question?
Thursday, September 2nd, 2010 AT 6:53 AM
  • 108,192 POSTS
Have you checked to make sure the catalytic converter isn't plugging? As far as the IAC or TPS, they can cause the computer to change fuel / air mixtures.
Thursday, September 2nd, 2010 AT 8:57 AM
ALANSS454
  • 7 POSTS
I have unhooked the exhaust from the turbo and it
makes no difference. If you change the cam timing the
car has better power but then the idle is way to high.
The power band starts at about 3,000 rpm with the cam
timing moved but has no power when in the correct
setting.
Thursday, September 2nd, 2010 AT 9:14 AM
  • 108,192 POSTS
When you change engine timing, what are you changing it to?
Thursday, September 2nd, 2010 AT 10:02 AM
ALANSS454
  • 7 POSTS
I move it to full advance so I can get power but when
I bring it back to specs it is a turd.
Thursday, September 2nd, 2010 AT 10:33 AM
  • 108,192 POSTS
I can't remember if the 92 had a mechanical or vacuum advance. Can you tell if it is working?
Thursday, September 2nd, 2010 AT 11:23 AM
ALANSS454
  • 7 POSTS
It has an electrical plug going to the to the cover, when
unhooked the car shuts off.
Thursday, September 2nd, 2010 AT 11:34 AM
  • 108,192 POSTS
It is done by the computer. I was hoping you didn't say that. Based on everything we discussed, either the distributor is bad or the ECM is not advancing the timing when needed.
Thursday, September 2nd, 2010 AT 12:53 PM
ALANSS454
  • 7 POSTS
This car has no distributor, I am changing only the cam
timing.
Thursday, September 2nd, 2010 AT 2:01 PM
  • 108,192 POSTS
That is what I thought. If you are getting no advance from the computer, that is the direction I would go.
Friday, September 3rd, 2010 AT 7:02 AM
ALANSS454
  • 7 POSTS
Why would that affect the idle?
Friday, September 3rd, 2010 AT 7:10 AM
