How to change power steering hose
2CP-ARCHIVES
  • 1995 OLDSMOBILE CUTLASS
  • 6 CYL
  • 135,000 MILES
1995 Oldsmobile Cutlass Supreme mileage: 135,000. What do I need to do to change the high pressure power steering hose. Are there any tricks?
Tuesday, November 9th, 2010 AT 12:19 AM
2CP-ARCHIVES
  • 4,540 POSTS
Its a good idea the disconnect the battery and then jack the car up. Here is a guide and a video on how to change the high side hose out.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
and
https://youtu.be/BGBUv5r9fk0
Cheers, Ken
Tuesday, November 9th, 2010 AT 12:21 AM
BIGDADDYJQ
Super helpful. Removing the fittings is obvious. I too have the 93 Cutless Supreme with the 6cyl (x). If it were only that easy. Removing the fitting from the pump is easy. I found that removing the Coolant reservoir and the plastic shroud that protects electrical wires from the S. Belt and pulleys makes it easier to remove the mounting bracket down below. It is the fitting that attaches to the steering column is where the difficulties are. I found that by removing the air box and flex tube to the throttle body helped me gain limited access to the fitting. I am in the process of using a "crows foot" (18mm I believe) a short extension and a ratchet may be the answer to reaching the fitting. A stubby 18mm box wrench may work too, but its pretty tight in there. If anyone else has some good suggestions, I would love to try them.
Sunday, December 26th, 2010 AT 8:30 PM
NIGHTHAWK4699
  • 1993 OLDSMOBILE CUTLASS
Steering problem
1993 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
ok if there is anyone out there that could help me I have a 93 olds moblie cutlass and im trying to change the high pressure hose and im at the main bolt to the line and in wont come off I have tride a 18mm and it wont come lose I have put w-d40 on it and still nothing if anyone knows anything please help.
Friday, August 18th, 2017 AT 6:36 PM (Merged)
MIKT66
I had the same problem in my 94. But I couldnt reach it. When I took it into the shop they had to lower the engine 6 inches and use some crazy special tool to get it off. With labor and parts it cost me 260. Good luck
