Have you tried to jump start it?
Unless there is a issue with wiring you should get dash light to come on.
When you turn the key does anything happen at all? Sounds like a drained battery so we should load test it but if you try and jump start it and get more action out of it then that would indicate a battery drain issue.
Here are a couple guides that will help with this. Let's start with jump starting it and going from there.
https://youtu.be/dCjmRL3p4Cs
https://www.2carpros.com/articles/how-to-jump-start-car-battery-using-jumper-cables
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
If your 2011 Nissan Sentra is not displaying any dashboard lights and is not starting, it could be indicative of an electrical issue. Here are a few possible causes to consider:
Dead Battery: Check the battery voltage and ensure it has a sufficient charge. If the battery is dead or the connections are loose or corroded, it can prevent the electrical system from receiving power.
Faulty Ignition Switch: The ignition switch is responsible for sending power to various components, including the dashboard lights and the starter. A faulty ignition switch can cause a complete loss of power and prevent the vehicle from starting.
Blown Fuse: A blown fuse in the electrical system can result in a loss of power to the dashboard lights and other vital components. Inspect the fuses and replace any that are blown.
Faulty Starter Motor or Solenoid: If the starter motor or solenoid is not functioning correctly, it can prevent the engine from starting. You may hear a clicking sound when attempting to start the vehicle if this is the case.
Malfunctioning Body Control Module (BCM): The BCM is responsible for controlling various electrical functions in the vehicle. If it malfunctions or fails, it can result in a loss of power and prevent the vehicle from starting.
Let me know little more info and I am sure we will be able to figure this out.
SPONSORED LINKS
Saturday, August 7th, 2021 AT 9:15 PM
