1987 Nissan Pathfinder
TAMPICO
  • 1987 NISSAN PATHFINDER
  • 4 CYL
  • 4WD
  • MANUAL
  • 324,000 MILES
ENGINE SPUTTERS IRRATICLY, IDILING, MID-
RANGE, UNDER POWER, NOT ANYTHING
CONSTANT
SOMETIMES SEEMS TO RUN FINE, THAN WILL
SPUTTER, NOT SEVERLY
SOMETIMES WILL SPUTTER SO BAD IT DIES
NEW, PLUGS, PLUG WIRES, DIST. CAP, ROTOR,
FUEL FILTER,
PROBLEM DOES NOT APPEAR TO BE FUEL DELI
VERY ISSUE, OBSERVE CONSISTANT FUEL INTO
TROTTLE BODY
"BRAIN" APPEARS TO BE IN WORKING ORDER
NO VISUAL DEFECTS(BURED DIODS, RELAYS)
WIRES TO "BRAIN" ARREAR FINE
WILL START AND IDLE COLD OR HOT
THOUGH STILL OCCATIONALLY SPUTTER
ENGINE DOES SMOKE, BUT NOT SEVERLY
MOST OF THE TIME CANT SEE ANY
Do you
have the same problem?
Saturday, May 9th, 2009 AT 12:48 PM
KHLOW2008
  • EXPERT
Hi TAMPICO,
Thank you for the donation.
Thee are various possibilities such as :
1. Throttle position sensor.
2. Air flow meter (AFM). Check if the sensor inside air flow is dirty. Use air flow spray cleaner to clean it. Be careful not to damage it with any physical contact.
3. Crank angle sensor.
4. Cylinder head temperature sensor.
Is the Check Engine Light showing?
Did you try to go into diagnostics.
Sunday, May 10th, 2009 AT 4:44 PM
Recommended Guides
