Fuel Filter Location
BEVANS1942
  • 2001 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 69,000 MILES
Where is the fuel filter?
Thursday, March 17th, 2011 AT 3:20 AM
The fuel filter is inside the gas tank this guide will help you change it out and check out the diagrams below to show you on your car.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Thursday, March 17th, 2011 AT 3:24 AM
616RAUL
  • 2000 NISSAN MAXIMA
  • 6 CYL
  • AWD
  • 180,000 MILES
Can some body tellme if the fuel filter on a 2000 nissan maxima is locate below the rear sit or below the driver sit
Tuesday, January 8th, 2019 AT 8:02 PM (Merged)
Its under the rear seat cushion
MJL89
  • 1996 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 140,000 MILES
How do I remove the hoses without damaging them?
I've loosened the clamps, but hoses are stuck onto filter.
Either you pull it right off or cut the hose if there's slack to reattach or replace the hose-
AMANDA LYNN
  • 1998 NISSAN MAXIMA
  • 214,563 MILES
My car is missing but once you get it stretched out on the highway it hardly does it. We have replaced the spark plugs and put gas treatment in. We are going to replace the fuel filter. Trying to find out how much it will cost
  • 108,300 POSTS
It should be around 75.00. Based on where you live it could be different.
Tuesday, January 8th, 2019 AT 8:03 PM (Merged)
DJCL
  • 767 POSTS
Its pretty rare that a fuel filter would do that. To save some money remove it and blow thru it to see if it is restricted. If it was the car would run bad all the time. If its clear I would start checking other things. Computer codes would be a good start
AMANDA LYNN
Thank you very much
DJCL
  • 767 POSTS
No problem
PALE
  • 1994 NISSAN MAXIMA
Engine Mechanical problem
1994 Nissan Maxima
my car acts like its running out of gas when it has gas. How do I change the fuel filter?
Might not be the fuel filter-to prove it-check the fuel pressure with a gauge before and after the fuel filter
NATESXTN
  • 4 CYL
  • 115 MILES
How to replace a fuel fiter on a 96 maxima
JDL
  • 16,098 POSTS
The filter should be close to brake master cylinder. Make sure there is no pressure on system before taking any lines loose. Pull fuel pump fuse, start vehicle, let it run till it stalls, try more than once. Even then, be aware of fuel in the lines.
FREDDY54
  • 1992 NISSAN MAXIMA
1992 Nissan Maxima 6 cyl
where is the fuel filter located
https://www.2carpros.com/forum/automotive_pictures/12900_ff_35.jpg
FARLEY 1954
  • 1986 NISSAN MAXIMA
Engine Performance problem
1986 Nissan Maxima
where is the fuel filter. Is it hard to change
EUGENE123
  • 273 POSTS
Under hood, driver side, rear engine area, passenger side of master cylinder, mounted on firewall. Not very hard to change but they can be a little tricky ;)
MORGANLISA
1992 Nissan Maxima 6 cyl Automatic
can you tell me where the fuel filter is located?
ECCS Component Parts Location
https://www.2carpros.com/forum/automotive_pictures/12900_fuelf_2.jpg
FUEL FILTER
Located in the rear of the engine compartment, near the brake power booster unit.
