Firing order?
ANONYMOUS
  • 2007 NISSAN ALTIMA
  • 165,000 MILES
What is the firing order for the 2.5 L 2007 altima?
Tuesday, February 26th, 2013 AT 7:51 PM
DOCFIXIT
  • 18,828 POSTS
Here is the firing order in the diagrams below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Thursday, August 3rd, 2017 AT 9:03 PM
AJRC11111
  • 2005 NISSAN ALTIMA
  • 140,246 MILES
The vehicle is missing. Had a friend put vehicle on a diagnosis. As a result the coding is reading the #4 cylinder is misfiring.
Thursday, January 21st, 2021 AT 10:16 AM (Merged)
DRCRANKNWRENCH
  • 3,380 POSTS
Firing order is:
1-3-4-2.
AJRC11111
Thanks for the quick response. My first bet is to check the wires and plugs from there can you suggest what else I can look at?
DRCRANKNWRENCH
  • 3,380 POSTS
When you check the plug wire test it for continuity. You can do this with a multi-meter, you can get a multi-meter for less than $10.00 at Auto Zone or Advance Auto. Keep these places in mind as they read trouble codes for free, and test the wire for resistance. It should have some number of ohms. If it has infinite resistance, the multi-meter instructions will explain how it is displayed, then the spark plug wire is not a continuous wire and will not carry electricity and needs to be replaced.
If all that checks out, get the trouble codes pulled at the aforementioned stores. They will give you a reading of any electrical issues with the car.
MR TURBO
  • 2002 NISSAN ALTIMA
  • 4 CYL
What is the firing order on a 2002 Nissan Altima with a 2.5?
Thursday, January 21st, 2021 AT 10:17 AM (Merged)
Here is the engine spark plug firing order. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
JONIMAHAFFEY
  • 2001 NISSAN ALTIMA
Four cylinder front wheel drive automatic 103,000 miles 2.4 liter engine.
I recently changed my spark plugs and a few things have happened. Got water in number one, number two wire melted on metal wire holder. I have purchased new wires and not sure of the order on distributor cap. Can you help? Thanks Joni
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
the firing order is 1-3-4-2
Here is a diagram so you can see for yourself (below) and where #1 cylinder is. Please let us know if you need anything else to get the problem fixed. Cheers, Ken
