Changing alternator
CRAZYCRICK
  • 2005 NISSAN ALTIMA
  • 6 CYL
  • FWD
  • 87,000 MILES
Need help changing alternator. I have changed several on old cars but I am not sure if it comes out the top or bottom. Also, what all has to be loosened/taken off for it to come out?
Tuesday, January 13th, 2009 AT 11:51 PM
GFIMOTORCARS
  • 673 POSTS
Here is the order in which you will want to remove this alternator:
1. Disconnect the battery
2. Remove the engine undercover
3. Remove the radiator (instructions below)
4. Remove your drive belt (instructions below)
5. Remove your enigne idler pulley
6. Disconnect the alternator wires
7. Remove the alternator adjustable top mount
8. Remove alternator lower bracket
9. Slide the alternator out, you should have plenty of room
https://www.2carpros.com/forum/automotive_pictures/294900_Alternator_1.jpg
Radiator Removal
1. Drain coolant from radiator
2. Disconnect your upper and lower radiator hoses.
3. Remove your transmission cooler lines from the radiator and plug the lines.
4. Disconnect the reservior tank hose
5. Remove the radiator mounting brackets
6. Remove the radiator and radiator fan assembly
Drive Belt Removal
1. Drive belt tension is relieved by using a wrench or ratchet and socket to turn tensioner bolt, see tensioner location in picture.
https://www.2carpros.com/forum/automotive_pictures/294900_Drive_belt_35L_1.jpg
Let me know if you need any more information.
Wednesday, January 14th, 2009 AT 12:22 AM
CRAZYCRICK
  • 5 POSTS
And this is for a 2005 Altima V6 correct? The MB symbol confused me. Sounds like taking the radiator off is the big problem. Is that correct? Thanks for all the help. Sounds like it is going to be a job.
Wednesday, January 14th, 2009 AT 12:39 AM
GFIMOTORCARS
  • 673 POSTS
That is correct. The MB symbol is for my repair shop here in California, we specialize in MB vehicles, but work on all makes. But yes this is for an 2005 Altima 3.5L V6. It will be a bit of a job but do not let the radiator removal discourage you. It actually is not terribly difficult and is really only held on by a couple of upper retainers that are easily removed from the upper radiator support. After you disconnect the hoses and transmission lines the radiator and fan will pretty much just slide out. But all in all this will be a good days work if your not familiar with the vehicle.
Wednesday, January 14th, 2009 AT 2:23 AM
CRAZYCRICK
  • 5 POSTS
I got the alternator changed. Now when I stop at a red light the heater goes cold. I figured out today that when I turn the AC and the recirculate off it does not do it. Any ideas? Thanks again.
Thursday, January 15th, 2009 AT 10:18 PM
GFIMOTORCARS
  • 673 POSTS
Was this a previous issue or did this just start after the repair? If it happened immediately after the repair it is more than likely related to the repair. Check your coolant level, a lot of times your system will burp after you fill it and drive awhile leaving room for much more coolant. Also, check to make sure you have no leaks and that all coolant hoses are clear of kinks. Let me know what you find.
Thursday, January 15th, 2009 AT 11:14 PM
JEREMY_LDR
I am trying to take out my alternator and cannot get to the bottom nut. It is stripped out and cannot get it off. Any ideas?
Saturday, January 22nd, 2011 AT 11:22 PM
MAX18117
  • 3.5L
  • 6 CYL
  • 107,000 MILES
I am trying to replace alternator and cannot get to the bottom nut. It is stripped out and cannot get it off. Help ASAP! Your Ideas will be greatly appreciated. Tom
Tuesday, July 24th, 2018 AT 5:56 PM (Merged)
CJ MEDEVAC II
  • 222 POSTS
Try holding pressure on the nut outward while you spin it this will help you remove it. Here is a guide to help you remove the alternator and the diagrams below to show you how it is done on your car:
https://www.2carpros.com/articles/how-to-replace-an-alternator
Cheers
CRAZYCRICK
  • 5 POSTS
  • 6 CYL
  • FWD
  • 87,000 MILES
How do I get the alternator off of my car listed above. Looks like the whole motor has to come out. HA
Tuesday, July 24th, 2018 AT 5:57 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Thanks for the donation.
To remove your vehicles generator (alternator) perform the following operations. This does require the removal of a few major components such as the radiator, so if you need further assistance with one of the removal procedures for a component such as the radiator, just let me know and I will post guidance.
REMOVAL
Disconnect negative battery terminal.
Remove radiator.
Remove front/right-side engine undercover.
Remove drive belt.
Remove idler pulley.
Remove generator adjustable top mount, using power tools.
Remove generator lower mount bolt and nuts, using power tools.
Remove generator lower front bracket bolt, using power tools.
Disconnect generator harness connectors.
Slide generator out and remove.
INSTALLATION
Installation is in the reverse order of removal.
Torque bolts to specifications listed on diagram below.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_131.jpg
Hope this helps..
Thanks for using 2carpros.com!
LEECG
  • 3.5L
  • V6
  • FWD
  • MANUAL
  • 177,000 MILES
Not charging.
WRENCHTECH
  • 20,758 POSTS
Check for power at the main terminal with the key off. Post what you find.
WRENCHTECH
  • 20,758 POSTS
Did I read this right? Have you already changed the alternator and still have a problem?
OUTKRY
  • 6 CYL
  • FWD
  • 80,000 MILES
Alternator replacement information in layman's terms. Please
DONDWEJR
  • 4 CYL
  • FWD
Changing alternator, something shorted now no electrical. How to fix?
CARADIODOC
  • 33,755 POSTS
Look for a large fuse that is bolted into the under-hood fuse box to see if it is blown.
DADDYS SUGAR BEAR
  • 2004 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • 41,322 MILES
HOW DO I REMOVE BELT SO I CAN REMOVE ALT.
Wednesday, September 25th, 2019 AT 7:30 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Loosing the belt by moving the tensioner pulley away from it
https://www.2carpros.com/forum/automotive_pictures/99387_altima_belt_1.jpg
ERIKFAST
  • 6 POSTS
  • 2002 NISSAN ALTIMA
  • 4 CYL
  • MANUAL
  • 99,350 MILES
How do I replace the alternator on a 2002 Nissan Altima? I have removed the electrical components and The top bolt. The bottom bolt is obstructed by a black box (which I assume to be the computer). Also, the belt seems to be an obstacle.
BLUELIGHTNIN6
  • 16,542 POSTS
Depends on which engine you have. The QR25DE is easier to work with, you just remove the right front engine undercover to access the belt and alternator. On the VG35DE you will have to remove the entire radiator for this job though.
