Neutral safety switch location and testing?
ANONYMOUS
  • 2009 CHEVROLET IMPALA
  • 80 MILES
Where is the neutral safety switch located?
Friday, February 8th, 2013 AT 7:50 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 52,325 POSTS
Hey,
the neutral safety switch is located inside of the transmission right under the gear selector arm here is a wiring diagram so you can test the wiring to help fix the problem with the location of the internal mode switch as they call it below.
Check out the diagrams (Below). Please let us know what you find.
Thursday, December 29th, 2016 AT 6:19 PM
LYNDA MORRISON WHITE
  • 2005 CHEVROLET IMPALA
  • 3.8L
  • 6 CYL
  • FWD
  • 200,000 MILES
Mechanic told me I needed new NSS for no-start issue. Can the NSS be bypassed?
Wednesday, March 17th, 2021 AT 4:06 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
No, you cannot bypass it. It controls a lot more than just the starter circuit. It tells the computer what gear it is in so the computer can make decisions.
STEVEN64.GRAINGER
  • 2001 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 160,000 MILES
Where is the neutral safety switch on a 2001 chevrolet impala located? I was told inside the transmission. That the transmission needs to come out to replace it. I'm about 99% sure thats incorrect. So "Help".
BLUELIGHTNIN6
  • 16,542 POSTS
The park / neutral position switch is located INSIDE of your vehicle's transaxle and it will require a lot of labor hours to replace.
