1997 Mercury Sable no start in cold
NIEVESINS123
  • 1997 MERCURY SABLE
  • 6 CYL
  • FWD
  • 87,450 MILES
The engine cranks but doen't start in extreme cold
Monday, March 2nd, 2009 AT 10:14 AM
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Monday, March 2nd, 2009 AT 10:52 AM
