HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mercury
Cougar
Engine
Symptoms
Not Running
1999 Mercury Cougar Moving car from park to drive
KB26
MEMBER
1999 MERCURY COUGAR
6 CYL
2WD
AUTOMATIC
11,000 MILES
I'm starting car, which is fine. But when I go to put car in drive, it refuses to get in gear
Monday, January 14th, 2008 AT 4:53 PM
MASTERTECHTIM
MECHANIC
Do you mean the shifter does not move? Will it go into D but not move
Monday, January 14th, 2008 AT 5:03 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
My Mechanic Is Stumped '99 Mercury Cougar
Recently When I Started My Car I Would Turn The Key And Nothing Would Happen. No Noise; Nothing. Then After Holding It A Few Seconds I...
Asked by
thephoenix1313
1999
MERCURY COUGAR
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Engine Quit Running While Driving And Will Not Start...
I Was Driving Along And It Just Quit Running. I Check To See If It Fires And It Does And It Is Getting Gas.
Asked by
Opal Justice
21 IMAGES
2001
MERCURY COUGAR
Engine Cranks But Not Starting?
Thought It Was + Battery Cable Because It Was Very Detatched At Connectors And When It Was Wiggled It Starts. Changed The Connectors And It...
Asked by
djangell
14 IMAGES
2000
MERCURY COUGAR
Engine Not Running?
I Have A 1997 Mercury Cougar Xr7 With A 4.6 V-8 With Cranking Issues.I Have Replaced Plugs, Plug Wires, Crank Position Sensor, And...
Asked by
wgenesam
2 IMAGES
1997
MERCURY COUGAR
Car Trys To Start But Wont
Car Wont Start Unless We Pull It And Pop Clutch But After That U Can Shut It Off And It Starts Right Back Up The Rest Of The Day Until...
Asked by
sbartlett136
1 ANSWER
2000
MERCURY COUGAR
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Replacement
