No dashboard lights no tail lights
KEEFERIS
  • 2002 MAZDA PROTEGE
Electrical problem 4 cyl Front Wheel Drive Manual 122639 miles
2002 protege 5, While driving I lose my dash board and rear lights, so I check my fuses, found the blown one and replaced with a good new one, turned my head lights on and it blows right away, I took both back tail lights out and tried a new fuse with the lights out of the holder and the fuse blows right away again, so I took the instrument cluster out and put in a new fuse with it out and the same thing happens, my head lights and turn signal lights, radio, inter lights all work just fine, so I'm pretty sure I have a short some place, but any idea as to the best place to start from?
Wednesday, February 13th, 2008 AT 1:25 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,072 POSTS
It sounds like you have a tail ight control relay that has gone bad but to be sure please follow this guide to test the relay.
If the relay checks out okay you need to check for a power wiring touching ground and the best way to do that is follow this guide to find the problem.
Here are the tail light wiring diagrams and relay and fuse panel locations (below)
Please run some tests and get back to us.
Cheers, Ken
Monday, December 18th, 2017 AT 1:45 PM
YAYO26
  • 1999 MAZDA PROTEGE
  • 4 CYL
  • AWD
  • 167,700 MILES
Electrical problem
1999 Mazda Protege 4 cyl All Wheel Drive Automatic 167700 miles
my in dash light does not work neither my tail lights and parking dash lights
Monday, December 18th, 2017 AT 1:45 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi yayo26,
Check the underhood fuse for taillight.
MIATAANNIVEDITION
Electrical problem
1999 Mazda Miata Anniversary Edition
I bought a 99 Mazda Miata Anniversary Edition last night. On the way home, the tail lights just quit working. All other lights, including back-up lights, seem to be okay. Fuses look fine. Where should I look for the source of the problem? Both sides went out simultaneously as I was driving. (Husband was behind me and saw them.) Thanks.
Check the tail fuse 15amp in the main fuse box if its blown if okay-test or swap the TNS relay with a similar one at right rear corner of engine compartment
MAZDA7
  • 132,000 MILES
My Mazda protoge's front fog light, side door light and back yellow tail light won't turn off. When I put the left turn signal on this happens. I unplugged the battery a couple of times and worked but now it isn't working. What do I do?
It has already killed the first battery that was in the car.
CADIEMAN
  • 3,544 POSTS
It seems like you might have a BCM that is failing causing the problem you have described. Please get back to us with your findings
