They say I need a new brake Master
GCEATTLE
  • 2008 DODGE CHARGER
  • 85,000 MILES
When I push the brake pedal it goes to the floor they say I need a new brake master.
Friday, June 14th, 2013 AT 10:22 AM
Here are a couple guides that will help with this issue and step by step instructions on how to replace this:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Below is the process from the manual that will give the detailed needed as well to complete this.
Please run through this material and let us know if you have other questions. Thanks
Saturday, June 5th, 2021 AT 1:27 PM
RIZ001
  • 6.1L
  • V8
  • RWD
  • 210,000 MILES
The brake master brake cylinder is leaking can you help me install a new one please?
Monday, June 28th, 2021 AT 7:43 PM (Merged)
  • 108,192 POSTS
Replacing the master cylinder isn't a difficult job. If you take your time, you should have no problem.
To get you started, here is a link that shows in general how it is done. You can use this as a guide.
If you look at the attachments below, they include the procedures for bench bleeding the new master cylinder and the removal and replacement of the old one.
I hope this helps. Let me know if you have other questions.
GEOFF.RESEESE
  • 2007 DODGE CHARGER
  • 75 MILES
Went driving the brake pedal falls to the floor, the master is bad.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. Here are tutorials showing how to install a master cylinder and bleed the brakes after the repair:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Before installing the master cylinder its best to bench bleed. Here is a YouTube video from our site showing what is involved:
https://youtu.be/WDxvEQrMkBg
I've attached picture steps below on how to install the master cylinder, bench bleed, and bleed the brakes after the repair on your car. Hope this helps and thanks for using 2CarPros.
