Starter relay location
SICHAVEZ
  • 2010 TOYOTA COROLLA
  • 1.8L
  • 4 CYL
  • 100,000 MILES
Where’s the starter relay located?
No crank, no start. Replaced couple of fuses.
Monday, June 17th, 2019 AT 12:13 PM
Hi Sichavez,
Attached is the location of the relay. Looks like it is in Junction Box 5.
This guide can help you test it
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Please let me know if you need more information. Thanks
Monday, June 17th, 2019 AT 12:44 PM
CANDACE SCURRY JONES
  • 2007 TOYOTA COROLLA
  • 16,240 MILES
Where is the starter relay located in the CE model?
Friday, January 8th, 2021 AT 7:17 PM (Merged)
  • 52,797 POSTS
Good afternoon,
It is in the junction box in the car under the left side (ST relay). I attached pictures for you of the location and where the relay is located as well. I also attached a wire diagram of the starting system for you. Check out the diagrams (Below). Please let us know what happens.
MARK YOSHINAGA
  • 6 POSTS
Are all starter relays in a Corolla blue in color?
  • 52,797 POSTS
No, relays can be different colors especially if they were replaced already.
JTTREVINO513
  • 2006 TOYOTA COROLLA
  • 4 CYL
  • 120,119 MILES
Car had juice from the battery but will not crank, only when it wants to and then it will start ten times in a row then nothing.
WRENCHTECH
  • 20,757 POSTS
That is commonly caused by a bad starter on those Toyota's. You can test for power arriving on the small wire at the starter when the key is held in "start" position.
JERRY MILLIKEN
  • 2004 TOYOTA COROLLA
  • 4 CYL
  • 12,000 MILES
Jump start and reversed cables.
Wednesday, January 13th, 2021 AT 9:34 AM (Merged)
CARADIODOC
  • 33,742 POSTS
The starter relay is in the inside fuse box on the left side of the dash.
If the jumper cables were switched, there are likely a number of blown fuses. Check those first if you have a problem you're trying to solve.
UPEREZ
  • 2003 TOYOTA COROLLA
  • 1.8L
  • 4 CYL
  • FWD
  • 109,290 MILES
I am looking for the starter relay and I cant find it?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
It is the ST relay in the relay/fuse box In the diagrams below.
Here is a guide that will help you test the relay along with a wiring diagram (below) so you can test the system.
and
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
2CP-ARCHIVES
  • 4,542 POSTS
  • 100,000 MILES
Where is the starter relay and fuse located?
KEN L
  • 42,904 POSTS
The starter relay is located on the passenger's side under the dash. Here is a guide to help test it.
ARTURO CHAVEZ
What is the resistance supposed to be for a corolla 05 for the starter relay?
DANNY L
  • 5,648 POSTS
Unfortunately you have attached your question to one that is years old.You need to start a new question including all your vehicle information.Hope this helps and here is the link.Thanks for using 2CarPros.
Danny-
SLICKRICK87
  • 1997 TOYOTA COROLLA
  • 4 CYL
  • 120,000 MILES
I had a no click no crank start issue and proceeded to replace the starter relay. When I replaced the relay the 30a fuse blew out. So I replaced it only to have it blow again. Did a little research online and decided to replace the ignition switch, the starter and replace the blow 30a fuse. After completing all this I went to reconnect the battery terminal and the starter started cranking the engine without me turning the key. It does this every time I try to reconnect it. Any advice would be very much appreciated.
  • 52,797 POSTS
Good afternoon,
Since all this started with the relay, I would go back to that. You may have the wrong relay or have installed it wrong.
I attached a diagram of the system for you to view.
Check for power to the relay with the key on. Then test for power on one terminal in the start position.
BEKIB
Would the starter relay cause the car to start in the on position, continue engaging the starter after the car is running until put into any other gear than park and then shuts the car off when put back into park? All its issues seem to be in the park position.
Sunday, March 26th, 2023 AT 4:20 PM
KEN L
  • 42,904 POSTS
No, it shouldn't, what year is your car so I can look up the wiring diagram to help you?
Wednesday, March 29th, 2023 AT 6:12 PM
