Blend door actuator?
JALLYSON
  • 2010 CHRYSLER TOWN AND COUNTRY
  • 37,500 MILES
This sound started when we turned on the fan, it lasts for about 8-15 bangs. Sounds like it is right in the glove box are. Now the sound it coming more often. Open doors with key fob, using the door lock buttons on the drivers side, I even heard it after I shut the car off waiting to pick someone up, I had been sitting for about 10 min when the loud banging/knocking went off. Please help is this a fan thing or an electrical thing
Monday, November 25th, 2013 AT 12:00 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
This sounds like you have a blend door actuator that has broken some gears which is common, they are plastic. Here is a guide that will give you an idea on what you are in for when doing the job. Remove the glove box door so you can get in behind it so you can feel which one is making the noise. I believe there are three or four of them.
Here is what it will be like on your car. (below)
Cheers, Ken
Wednesday, September 13th, 2017 AT 4:14 PM
TRACEY LEE MURPHY-TRIBNE
  • 2006 CHRYSLER TOWN AND COUNTRY
  • 3.3L
  • 6 CYL
  • 94,000 MILES
I have no heat. Changed radiator cap and put in new thermostat. Hear a clicking noise. It wants to open.
Tuesday, December 15th, 2020 AT 5:19 PM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
I have included the information that you requested in the diagrams down below. I have included the instructions from the vehicle manufacturer for your vehicle's blend door actuator removal and installation. Please go through this guide and report back with how everything turns out.
Thanks,
Alex
2CarPros
ROY KAY LIVEZEY
  • 2005 CHRYSLER TOWN AND COUNTRY
  • 136,000 MILES
A/C is blowing hot air in the front cabin, but blows cold in the back of the van. I believe the blend door may be stuck or broken, but I cannot find any diagrams showing the location of the blend door.
STEVE W.
  • 12,976 POSTS
There are multiple blend doors depending on which system you have. They are all located on the drivers side of the HVAC unit. The diagram shows the mode door and both blend door actuators. If you do not have the dual zone system up front you will be missing one of the actuators.
Once you install a new one you need to do a calibration.
The A/C-heater control module must be recalibrated each time an actuator motor or the A/C-heater control is replaced. If the vehicle is so equipped, the calibration procedure also includes rear HVAC positions for each actuator motor.
1 Turn the ignition switch to the "on" position.
2 If equipped with the manual temperature control (MTC) system, press and hold the rear wipe/wash and re-circulation buttons for at least five seconds. If equipped with the automatic temperature control (ATC) system, simultaneously press and hold the power and re-circulation buttons on the A/Cheater control for at least five seconds. The MTC A/C-heater control rear wipe/wash button light emitting diode (LED) and re-circulation button LED, or the ATC A/C-heater control Delay and re-circulation graphics will begin to flash when the calibration procedure has begun.
3 The calibration procedure should take less than two minutes to complete for the manual A/C-heater control, and less than twenty seconds for the ATC A/C-heater control. When the LED's or graphics stop flashing, the calibration procedure is complete.
4 If the LED's or graphics continue to flash beyond the two minute (manual) or twenty second (ATC) calibration time, it indicates that the A/C heater control has detected a failure and a diagnostic trouble code (DTC) has been set. The LEDs or graphics will continue to flash even after the ignition switch is cycled off and on, until a successful calibration is completed or until the vehicle has been driven about thirteen kilometers (eight miles).
Check out the diagrams (Below). Please let us know what you find.
JANDREWS319
  • 2003 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
I have a 2003 Chrysler Town & Country with an air flow problem. It has climate control which just had the controle module replaced late last summer. Everything has been fine up until recently. The air is hot or cold as it should be according to the settings but it's only coming out of the front and rear vents regardless of the automatic or manual settings. No air will come out of the floor vents or the defrost vents. Please help.
KEN L
  • 42,904 POSTS
Hey JANDREWS319,
This sounds like a blend door actuator problem. Here is some diagrams to show you which one to replace.
Here is a guide to help give you an idea on what you are in for when replacing one of them
Try to see if you can calibrate the system first. Here is the calibration procedure.
The heater-A/C control module must be recalibrated each time an actuator motor or the control module is replaced. If the vehicle is so equipped, the calibration procedure also includes rear HVAC positions for each actuator motor.
Turn the ignition switch to the ON position.
Simultaneously depress and hold the Power and Recirculation buttons on the heater-A/C control for at least five seconds. The manual heater-A/C control power Light Emitting Diode (LED) and Recirculation LED, or the Automatic Temperature Control (ATC) heater-A/C control Delay and Recirculation graphics will begin to flash when the calibration procedure has begun.
The calibration procedure should take less than two minutes to complete for the manual heater-A/C control, and less than twenty seconds for the ATC heater-A/C control. When the LEDs or graphics stop flashing, the calibration procedure is complete.
If the LEDs or graphics continue to flash beyond the normal three minute (manual) or twenty second (ATC) calibration time, it indicates that the heater-A/C control has detected a failure and a Diagnostic Trouble Code (DTC) has been set. Use a DRB III scan tool to perform further diagnosis. Refer to the appropriate diagnostic information. The LEDs or graphics will continue to flash even after the ignition switch is cycled OFF and ON, until a successful calibration is completed or until the vehicle has been driven about 13 kilometers (8 miles).
If that does not work you would need to take it in to have it scanned for trouble codes and diagnosed from there.
Hope the calibration works out for you.
Please let us know what you find so it will help others.
Best, Ken
GHINNERS
  • 2001 CHRYSLER TOWN AND COUNTRY
  • 150,000 MILES
I have no heat in my van. There is not one degree of heat coming out of the vents. I guessed after checking that the blend door was the problem and it was confirmed that it was. The repair garage wants $1100.00 to fix and I can not afford that repair so I have to do it myself. I am concerned about the airbags and don't know where to start to get step by step information to do this job.
Tuesday, December 15th, 2020 AT 5:20 PM (Merged)
  • 52,797 POSTS
This job can be done which will take some doing and you might need to loosen the dash and remove some obstacles to get to the mode door actuator. Here is a guide to walk you through the steps and diagrams below to show you how on your car.
DAVEMI
  • 1997 CHRYSLER TOWN AND COUNTRY
  • 150,000 MILES
Mode door actuator NOT changing mode from defrost to floor or vent. Can see Actuator part turning, but then a 'clicking' or knocking sound near top of dash results. Modes never change out of 'defrost'. What are our options to investigate further. Could an object have entered from top dash defrost vent, that could be lodged in the mode door or flapped? Or just plain broken part or gear?
Tuesday, December 15th, 2020 AT 5:21 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
What your going to have to do is remove actuator to see if the part that slides into the actuator is broken?If not make sure the door moves freely by hand if so I would say the actuator is bad.
J.STIEG
  • 352 POSTS
  • 2004 CHRYSLER TOWN AND COUNTRY
  • 3.3L
  • 6 CYL
  • 179,000 MILES
The rear blend doors are moving at different times and positions. Is there a way to relearn the positions?
Wednesday, December 16th, 2020 AT 8:19 AM (Merged)
STEVE W.
  • 12,976 POSTS
This is the book procedure.
If equipped with the automatic temperature control (ATC) system, simultaneously press and hold the power and re-circulation buttons on the A/C-heater control for at least five seconds.
The MTC A/C-heater control rear wipe/wash light emitting diode (LED) and re-circulation LED, or the ATC A/C-heater control delay and re-circulation graphics will begin to flash when the calibration procedure has begun.
If the LED's or graphics continue to flash beyond the two minute (manual) or twenty second (ATC) calibration time, it indicates that the A/C - heater control has detected a failure and a diagnostic trouble code (DTC) has been set.
Refer to body diagnostic procedures to perform further diagnosis. The LED's or graphics will continue to flash even after the ignition switch is cycled off and on, until a successful calibration is completed or until the vehicle has been driven about 13 kilometers (8 miles).
