A/C heater blend door actuator location
ANONYMOUS
  • 1996 FORD CROWN VICTORIA
  • 103,000 MILES
Need to find out where the A/C Heater Blend Door Actuator Is Located
Friday, December 7th, 2012 AT 4:22 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,072 POSTS
There are two style of blend doors one of them is right on top of the heater plenum. Here is a guide that will show you how to do it with diagrams below to show you on your car.
TEMPERATURE BLEND DOOR ACTUATOR
Removal
Disconnect negative battery cable. Remove instrument panel. See INSTRUMENT PANEL. Remove 4 temperature blend door actuator screws. Remove actuator from top of evaporator case.
(DIAGRAM BELOW)
1 18471 Heater Air Plenum Chamber
2 18A317 Vacuum Control Motor
3 18C433 Heater Outlet Floor Duct
4 389975-S2 Nuts
5 18A478 Windshield Defroster Door
6 - Windshield Defroster Door Crank Arm
Thursday, August 31st, 2017 AT 2:33 PM
BROTHERDELL
  • 1997 FORD CROWN VICTORIA
  • 4.6L
  • V8
  • RWD
  • 150 MILES
I need to know where the blend door actuator for ac/heat is located
Thursday, August 31st, 2017 AT 2:34 PM (Merged)
WRENCHTECH
  • 20,758 POSTS
It is located on the top of the HVAC housing and the dash has to be removed to access it.
]https://www.2carpros.com/images/external/133512984.jpg.gif
BROTHERDELL
Thank you :)
QUINJAM
  • V8
  • 345,400 MILES
I need to replace my blend door actuator on my 1996 Ford Crown Victoria but do not not know if I have manual or automatic air controls and they are sold as such, can you tell me how to distinguish between the 2? Thanks
Tuesday, June 25th, 2019 AT 1:47 PM (Merged)
WAY2OLD
  • 195 POSTS
He manual controls will have switches for the heat and another for the fan speed. The automatic system is more of a mini-computer that controls itself.
QUINJAM
Thanks
