2004 Kia Sorento Engine dies going down the highway
TZEAST
  • 2004 KIA SORENTO
Engine Mechanical problem
2004 Kia Sorento 6 cyl Two Wheel Drive Automatic
Engine just died. No warning, no surging, no sputtering. Someone said it sounded like a fuel pump. But the pump turns when cranking, but does not pressure up when key is on. Again someone else said a bad relay. I switched out the relay but no change. I will not start at all. But the pump runs while cranking. Disconnected gas return line and then cranked again. I seem to have gas pumping through line, although I am not sure what is normal pressure. But the pump is still turning when cranking.
Do you
have the same problem?
Thursday, October 23rd, 2008 AT 1:01 PM
  • EXPERT
Are you getting spark to the engine? Also, here is a how to for checking fuel pump pressure:
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Check that and let me know what you find. Finally, is the check engine light on?
Tuesday, October 13th, 2009 AT 12:11 PM
Recommended Guides
