High Oil Pressure in a 2000 Grand Cherokee
CFLOOD78
  • 2000 JEEP CHEROKEE
I have a 2000 Grand Cherokee Laredo 6-cyl 4wd with 89000 miles on it. The oil pressure has been 40 - 60 for the life of the vehicle, and all of a sudden it runs at higher pressure. It idles 40 - 50, and goes as high as 75 at higher speeds. I have recently had to replace the head gasket, but still have this issue.
Do you
have the same problem?
Thursday, April 5th, 2007 AT 4:45 PM
JACK42
What weight oil are you using and is it the correct filter?
Friday, April 6th, 2007 AT 8:09 AM
CFLOOD78
Valvoline Max Life 5w30 and a Valvoline Oil Filter
Friday, April 6th, 2007 AT 2:29 PM
MERLIN2021
  • EXPERT
Could be stuck pressure relief on the oil pump. Check the filter for bulging.
Friday, April 6th, 2007 AT 3:01 PM
CFLOOD78
44.00 at Napa.
20 minutes to get the stupid red pin plastic piece out securing the wiring to the unit. (It pulls from the bottom).
2 minutes to remove and replace.
Problem solved.
Thursday, May 3rd, 2007 AT 2:32 PM
Recommended Guides
