Remove and Replace Alternator
JPL1979
  • 1999 JEEP CHEROKEE
How do I remove and install new alternator?
Wednesday, August 4th, 2010 AT 1:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a guide to help walk you through the steps of changing the alternator with diagrams below to show you on your car.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Wednesday, August 4th, 2010 AT 2:19 AM
JPL1979
I own a 1999 Jeep Cherokee 4.0L V6. I have already purchased the new alternator. I don't own Torque wrench set. I do have socket wrenches. Will this be a problem?
Wednesday, August 4th, 2010 AT 2:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes you will have to torque the bolts properly or risk premature failure. You should be able to rent a torque wrench from a local auto part store though. Usually you just pay a deposit then borrow the tool, upon returning tool you get the deposit back.
Wednesday, August 4th, 2010 AT 2:27 AM
JPL1979
Ty
Wednesday, August 4th, 2010 AT 2:28 AM
YANWO
CAUTION: I believe at least some of the torque values given above are N-m, not ft-lb. One newton-meter is about 1.36 foot-pounds.
Thursday, August 8th, 2013 AT 1:48 PM
JAMESR
  • 1998 JEEP CHEROKEE
Electrical problem
1998 Jeep Cherokee 6 cyl Two Wheel Drive Automatic
How do you replace the Alternator. It's a 4.0L Classic.
Thanks
Friday, January 25th, 2019 AT 2:56 PM (Merged)
ANIMALFARM
  • 58 POSTS
I have a 96 straight 6 cherokee country. I recommend getting a HAYNES repair manual (20.00?) For your year model. There are many instructions, illustrations, pictures that will be useful in removing altenator. Too much info to post in this forum, and it will answer questions you didn't know you had. Good Luck!
BUDDCD
  • 2000 JEEP CHEROKEE
Electrical problem
2000 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
I need step by step instructions on how to replace alternator
  • 108,328 POSTS
Disconnect the battery, remove the serp belt, disconnect the power supply wiring on the back of the alt, unbolt it from the mount, and reverse the order to replace it.
MIYANJJ27
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • AWD
How do I change my alternator?
JDL
  • 16,098 POSTS
You remove it from underneath. If there is splash guard underneath, take one end loose, so you can move it out of the way.
Take negative battery cable loose, remove alternator belt. Remove electrical connector/s from alternator. As far as removing alternator bolts, use your own intiative as far as what to remove to get alternator out.
