1997 Jeep Cherokee is this the crank sensor?
ANGEESCRANG
  • 1997 JEEP CHEROKEE
1997 Jeep Cherokee 273000 miles
I broke down about a month ago. I turned the car off and when I got back it, the engine would turn over but not start. I got towed by a mechanic we know and he said it was the fuel pump and replaced that. The day we got it back, the car was starting funny. It would make noise but take a long time to kick in. When it finally did kick it, it would drive fine. We finally got around to bringing it back to the same mechanic who said that it is a problem with our crank sensor. Now, my question is: why did this start the day we got it back from having the fuel pump replaced? Did the fuel pump really need to be replaced or was it the crank sensor all along (the fuel pump we had replaced the year before)? Would putting in a new fuel pump make the car start even if the crank sensor was faulty? The car will eventually start up-- if it's the crank sensor, wouldn't it not start at all?
Do you
have the same problem?
Tuesday, December 16th, 2008 AT 2:56 PM
TGFISHEL
Not to sure. But you can check the sensor with a ohmmerter disconnect the cps electrical connector from the main wiring harness at the rear of the intake manifold check the resistance between the B and C terminals the meter should read no continuity or open if the reading are not to spec. Then replace the CPS.
Tuesday, December 16th, 2008 AT 3:32 PM
ANIMALFARM
Just had a very similar problem in my 1996 cherokee with 4.0 inline 6 - turned out to be the crankshaft position sensor. Jeep would crank but not start, no spark, no pressure in the fuel rail, only lights that would come on in the dash were the brake and seatbelt lights. All other electrical devices would work - power doors, windows, radio, headlights, etc.
The onboard computer would not spit out self-diagnostic codes, and would not interface with an OBD-II code reader.
I unplugged the CPS sensor connector in the engine compartment (right side of engine as seen from the front, at the back near the last fuel injector, oval shaped with three pins). After this, the check engine light came back, I had pressure in the fuel rail and could hear the fuel pump, and the computer would generate the self-test codes telling me that I had no CPS input. The CPS is located on the driver's side of the transmission bellhousing near the top, has two bolts holding it in place, and can only be reached from underneath. Size 11mm socket and several different extension sizes are necessary depending on the size of your hands. Mine wasn't too horrible to replace.
I used an ohm meter - holding the cps sensor connector with the plastic prong on top I measured the old connector from the left pin to the middle (approx. Zero ohms), and the right pin to the middle (infinity). On the NEW CPS sensor connector I measured the pins the same way and read infinity on both readings. It seemed to me that my old CPS sensor was shorted internally, plus disconnecting it from the circuit brought my jeep partially back to life, so it seemed like I was on the right track.
I hope this info helps, my jeep started first try and no problems so far.
Do you know if your cherokee has the ability to do a self-diagnostic and spit the codes out at you using the check engine light? I have a 1996 Jeep Cherokee that will do this when I do an on/off sequence using the key, but only if your check engine light is working.
To do this, turn the ignition key ON, OFF, ON, OFF, then finally ON. (On is the position just before that extra click that starts the jeep) The check engine light will blink the number of the first code digit(count the number of flashes), then pause about 2 seconds and blink the number of the second code digit. If you have more than one error code, the light will pause about 3 or 4 seconds, then blink the first and second digits of that code the same way as before. When the computer is finished blinking "codes". It will flash 5 times, pause, then flash 5 more times to tell you that is the end of the sequence. Post back with what you find out, and someone should be able to answer with more info if you need it. GOOD LUCK!
Wednesday, December 17th, 2008 AT 10:13 AM
Recommended Guides
