Camshaft marks
ECFWIRE2
  • 2002 ISUZU RODEO
  • 53,100 MILES
I need to know the positioning for the pulleys on a 2.2L Engine. Replaced the cam sensor put the timing belt back on and now the vehicle won't start
Sunday, April 22nd, 2012 AT 11:00 PM
  • 52,797 POSTS
Here is a guide and a diagram below
https://www.2carpros.com/diagrams/isuzu/rodeo/2002
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
Sunday, April 22nd, 2012 AT 11:07 PM
DMAPP05
  • 2002 ISUZU RODEO
  • V6
  • MANUAL
  • 200,000 MILES
I need full instructions on replacing timing belt.
Tuesday, October 2nd, 2018 AT 10:07 AM (Merged)
HMAC300
  • 48,601 POSTS
See pictures for instructions. There is a tsb but does not cover your car.
PLEICKHARDTJ
  • 2002 ISUZU RODEO
  • 6 CYL
  • 105,000 MILES
Setting cam timing on a 3.2 v 6 isuzu rodeo 2002, Also when setting the timing belt the book says top dead center on the first cyl but a site says cylender 2 so I am confused maybe you can help
BOSSGRUMBLER1
I need help with the timing on a 2002 iszuzu rodeo 3.2 motor
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,973 POSTS
Here is a link that will show you how to replace the timing belt on both 4 and 6 cylinder engines.
Cheers, Ken
LEBIRAMFELIZ
  • 2002 ISUZU RODEO
Engine Mechanical problem
2002 Isuzu Rodeo Question 6 cyl Two Wheel Drive Automatic
what are the timing marks, we repair the engine and the timing is not correct
BMRFIXIT
  • 19,053 POSTS
This link have it all
check it out
https://www.2carpros.com/car_repair_information/year/2002/make/isuzu/model/rodeo/2002_isuzu_rodeo_timing_belt_diagram_marks.htm
LAINE1
  • 2002 ISUZU RODEO
  • 6 CYL
  • 4WD
  • 148,800 MILES
I understand at the mileage I have I need to have the timing belt changed. I wa wondering if you
could tell me the labour time involved in this?
BLUELIGHTNIN6
  • 16,542 POSTS
Approx. 3.5 labor hours to replace your vehicle's timing belt.
BILLTHURSTON
  • 9 POSTS
  • 2002 ISUZU RODEO
  • 6 CYL
  • 4WD
  • 170,000 MILES
Well all I am going to give it a try and change the timing belt. Is there any advice from the pros out there? I plan to change the water pump also and the tensioner. Any help is always appreciated.
HMAC300
  • 48,601 POSTS
https://www.2carpros.com/manuals/manuals.php
it is best for you to rent book from that link as it is quite involved and to much for us to copy/paste. you will get all the mechanic's tips as well as tsb's as you can print out what ever you want I think it rents for a week.
JUNK214
  • 2001 ISUZU RODEO
Do I need to purchase any special tooling to replace the timing belt for a 2001 Isuzu Rodeo? Also, how do I differentiate the tension pulley from the rest of the pulley?
DOCFIXIT
  • 18,828 POSTS
Need to know engine size
JUNK214
V6.
DOCFIXIT
  • 18,828 POSTS
VERY complicated proceedure needs special tools LOTS of steps. Also if belt broke then valves are bent and head needs removed. If you do not have this type repair experience suggest you have this done.
JUNK214
OK, perhaps I misworded my question. I just need to replace my serpentine belt. How do I know which piece is the belt tensioner?
DOCFIXIT
  • 18,828 POSTS
That is a lot easier no special tool just wrench on tensioner nut push down ie. Clockwise to loosen tension
JUNK214
So which item number am I loosening? I loosened Item 6 two days ago and the belt stayed tight. And thanks for your help and patience.
  • 31,937 POSTS
What engine?
