Mass air flow sensor location?
ANONYMOUS
  • 2007 HYUNDAI ACCENT
Where is the location of MAF sensor?
Friday, March 15th, 2013 AT 3:27 PM
BLAZE45
  • 380 POSTS
This car has a MAP sensor not e MAF here is the location of the MAP. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Wednesday, March 20th, 2013 AT 11:44 PM
ALANANDREWS
  • 1.6L
  • 4 CYL
  • FWD
  • MANUAL
  • 123,000 MILES
I bought to CRC kit to clean the mass airflow sensor and the throttle body the throttle body. Is easy the mass airflow sensor I cannot find.
Sunday, December 6th, 2020 AT 8:11 AM (Merged)
HMAC300
  • 48,601 POSTS
The mass airflow sensor is self cleaning no need for that, but if you must it is between air filter and throttle body. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
KINGDRAGON6977
  • 1.6L
  • 4 CYL
  • MANUAL
  • 100,000 MILES
I know it sounds a bit dumb. My problem is that the previous owner cut and spiced a lot of wires on o2 sensors and wiring harness around injectors and throttle body. The book I have says it's suppose to have one also, other sites online. But I can't find part in any auto parts store for it. If I search for it under 2006 I can find after market but not for 2007, any help would be great thanks.
  • 52,797 POSTS
Good evening,
The simple answer is no. They use a MAP or manifold absolute pressure sensor instead.
What is your concern that makes you ask this question?
DAVE1310
  • 63 POSTS
  • 2002 HYUNDAI ACCENT
  • 140 MILES
On the listed car(2002 Hyundai Accent GL 1.6ltr.), Where is the Mass Air Flow located I want to clean it because I have a rough idle I have replaced the plugs, wires, coil pack already, but I need to know where is the MAF?
KHLOW2008
  • 41,815 POSTS
The system do not use any MAF. A MAP is used and usually erratic idling is caused by the ISC (IAC) and throttle plate being dirty. You should have them cleaned first.
Item #3 in diagram is the ISC.
DAVE1310
  • 63 POSTS
Thanks
I have one on order already-throttle plate cleaned-do I need to clean the MAP in any way?
KHLOW2008
  • 41,815 POSTS
No, do not attempt to clean the MAP sensor, it is a sensitive component and can be damaged easily. It works on vacuum so would not get dirty.
DAVE1310
  • 63 POSTS
Thanks-by the way my IAC came in, put it on and the car runs well
KHLOW2008
  • 41,815 POSTS
You're welcome.
Usually cleaning it would be sufficient unless trouble codes are present.
Have a nice day.
DAVE1310
  • 63 POSTS
Yeah-I had PO1505 code(open circuit, weak input I think that's what it was, but I know I had a code that indicated the IAC)-it seems OK now-Thanks again for your help
KHLOW2008
  • 41,815 POSTS
You're welcome :)
EMMARSH
  • 2001 HYUNDAI ACCENT
  • 4 CYL
  • MANUAL
  • 38,000 MILES
Hello, I'd appreciate some advice if anyone can help. I bought this car last week and it's been driving fine but the engine check light came on after a few days. I took it to a Hyundai dealer today and they diagnosed that it was the air flow sensor that needs replacing. At the same time I asked them to listen to the the aircon (which was sounding rough) and they advised it would be expensive to repair - as I'm not bothered about aircon they have just disconnected it for me (so I can use the window fans without it coming on automatically). I'm taking the car in to have the part replace next week. What's concerning me is that when I drove home today the car isn't driving fine anymore although the check light isn't on! It isn't accelerating properly and is really jumpy. Should I be worried about this? Is it just because they've had a dig around in the sensor and made it worse?
Thanks,
Elizabeth
2CARPRO JACK
  • 11,533 POSTS
Scanning for codes wont make it any worse, but the sensor could be failing all on its own. When the MAF starts having trouble it will make the car do alot of different things. If the code pertained to that, have it replaced and go from there
MYLITTLEHYUNDAITHATCOULD
  • 2000 HYUNDAI ACCENT
  • 4 CYL
  • AWD
  • 89,000 MILES
My 2000 Hyundai Accent is putting out smoke whenever I accelerate.
At first the smoke is white and then as I drive, it turns gray.
First, I want to know what might be causing the smoke.
Second, I want to know if I can fix it myself. I just spent about 300 on changing is mass air flow.
I got synthetic oil and gave it an oil change. That lessened the smoke but there's still some coming out.
Thank you!
-Christina
Sunday, December 6th, 2020 AT 8:12 AM (Merged)
  • 108,192 POSTS
Christina:
IT sounds like you have a bad head gasket. Coolant enters the combustion chamber and burns producing white smoke. Have you had to add coolant to the vehicle? Also, check the oil to make sure coolant isn't getting in there. Finally, one way to check it to perform a compression test. If you need directions, let me know.
NATE7410
  • 136,000 MILES
Hi I have a 2000 hyundai accent with a engine light on it is code p 1128 fuel system lean part load, I have checked for vacuum leaks and I have cleaned the throttle body, also I have clean the mass air flow sensor, the car runs fine. What else should I check?
KHLOW2008
  • 41,815 POSTS
Replace the MAF. Quite common for it to cause problems when it is not working correctly without throwing trouble codes indicating it is faulty. Someone had replaced 3 MAF to finally resolved the probem.
