1998 Hyundai Accent getting no spark after dies
LLUCKTHREE9
  • 1998 HYUNDAI ACCENT
  • 4 CYL
  • 102,000 MILES
My car will start and run good for 20 minutes then it dies, wiat 30 minutes to hour it wll start again runs good for 20 minutes, check spark pugs when first dies no spark
Do you
have the same problem?
Sunday, February 22nd, 2009 AT 7:15 PM
BMRFIXIT
  • EXPERT
Check and replace crank sensor
Sunday, February 22nd, 2009 AT 7:18 PM
LLUCKTHREE9
Thats not answer I bought the crankshaft sensor it still does smae thing anwer my vw cabroilet question I paid 5.00 for that
Wednesday, February 25th, 2009 AT 12:32 PM
BMRFIXIT
  • EXPERT
Was the timing belt checked?
Wednesday, February 25th, 2009 AT 4:28 PM
LLUCKTHREE9
No but will the car run if timming belt is off, my car starts runs good for 19 minutes then it dies then wont start for another 20 minutes when it cools down then it starts again runs good for another 20 mintes no spark inbetween time when car does not run
Thursday, February 26th, 2009 AT 12:42 AM
BMRFIXIT
  • EXPERT
Yes you are correct on that with the timing belt
It sounds so much like a bad crank sensor !
Scan it for codes and check pending codes too
use an ohm meter and check coil
check relays
again you have no spark after it stalls on you?
Fuel?
Thursday, February 26th, 2009 AT 3:38 AM
LLUCKTHREE9
Right, but wait 30 minutes then it start up runs good
Thursday, February 26th, 2009 AT 11:44 AM
Recommended Guides
