Fuel filter?
SSELANTRA2004
  • 2004 HYUNDAI ELANTRA
  • 4 CYL
  • 81,000 MILES
I have taken adequate care of my Elantra, regular oil changes, transmission oil changes.
Last few months it seems like it has lost some power, sluggish and sometimes does not downshift smoothly while driving on an upgrade or accelerating.
The car shop replaced the fuel filter (without telling me first) for $175 then charged another $200 to change the Throttle position sensor. Since then, the RPM's race all over, car hesitates, hiccups, wants to cut while stopped at a light. When I start up first thing in the morning (cold engine) the RPM's can race to 4000. On idle the engine runs rough.
Took it back - shop said it might be a bad part. They said they changed it and the car ran ok for 3 days. Now the same problems are back. I told them I didnhave any of these problems BEFORE I took it in. They are giving me the run around and say they need to do "more tests."
I have no check engine light (CEL) warnings.
A friend said it might be the fuel filter or pump. He looked at the seat and there is no indication that it was removed - I understand that's the way to get to the fuel filter. I called the shop and asked how they changed the filter. The answer I got was "we didn't remove the seat or the gas tank. The fuel filter is outside the gas tank."
I don't know enough about my car to verify this. Does the Hyundai Elantra 2004 have a fuel filter OUTSIDE the gas tank?
Also, I am leery about taking my car to these guys again. Can you tell me what could be the problem if changing the TPS didn't help much?
thanks.
Saturday, May 1st, 2010 AT 7:01 PM
  • 108,269 POSTS
Hi:
First, yes the fuel filter is under the car and nothing needs removed to access it. So they are being honest about that; however, the price they charged seems really high. As far as the idle problem, since when they replaced it the second time it ran good, something tells me they are getting bad parts. Many shops will get the cheapest parts they can. If they still feel it has to do with the TPS (and they guarantee you that is the problem) have them reimburse you for he original TPS and spend the extra money on one from the dealer.
Honestly, I don't think they ever fixed the original problem. A loss of power and running rough usually indicates a plugged catalytic converter. Have them check that too.
Tuesday, April 16th, 2019 AT 6:56 PM
SSELANTRA2004
Thanks for the feedback on the catalytic converter.
The shop says they will charge for a computer diagnostic check. That might be another $100 When I contacted them, the guy didn't make any effort to offer to look at the TPS. I might have to stay away from them and go to another shop.
Re - catalytic converter - is that a big cost? It seems like when I start up the car the smell from the exhaust is really weird. Not exactly rotten eggs smell. But bad.
Someone mentioned checking the following:
manifold gasket?
Pulse Generator Wires
idle speed
Oxygen sensor
Any thoughts?
Thanks
  • 108,269 POSTS
Rather than going back to them for a computer diagnostic test, take it to a nationally recognized parts store. Most will do it for free.
Now for the converter, a direct fit part can be around 200 dollars based on where you live. Here is something you can look for. After driving at night, do not shut it off and get out and look at the converter. Many times when they plug, they will get so hot that they will glow red hot (easy to see at night).
As far as the other items mentioned, the intake manifold gasket would have caused an idle problem, the O2 sensor rough idle, increased fuel consumption, and I'm not sure about what they ment by idle speed, or pulse generator wires. THey may have been refering to the injectors, but that would have caused the engine to shut down, miss.
Regardless, let me know what you find or if you have other questions.
SSELANTRA2004
Thanks for the guidelines. I'm in So Cal and unfortunately, Autozone and other parts stores are no longer allowed to do diagnostic checks in-state. Laws here are getting stranger!
I drove the car 40 miles r/t yesterday (freeway) and on the last 10 miles or so, the RPM wouldn't go below 3000 so I drove at 40 mph to home. This morning when I started the engine and drove about a mile the CEL light came on. So it is now parked at work.
I am thinking of taking it to another shop to get it checked. It might be the catalytic convertor or the previous shop just messed up the TPS and/or fuel filter installation.
It is a great car, fully loaded and I would like to drive it for a few more years. Will give update when (hopefully) the problem (s) get solved without breaking the bank.
  • 108,269 POSTS
Wow! They can't check because of new laws? I guess thats big brother keeping an eye on us and trying to protect us. If I recall, "we the people" built this country. What is next. I know I have had about all I can take. This poor country. One can bearly recognized it anymore. What happened to the freedom to pursue happiness. The more you make the more they take. The harder you work, the more you are punnished. Why try?
What the nationally recognized parts stores offered was a great for people who needed help and couldn't afford an extra hundred bucks to get a computer scanned. The parts stores, of course, hoped you got the parts from them, but that is gone for them. Just keep feeding the people who overcharge for everything.
Sorry about my whining. I'll shut up now. But what is right, is right, and they have the same freedom to boost their sales as anyone. There I go again.
Sorry about the political views. Let me know what you find and I'll do my best to help you. Also, let me know if the car still runs now that the light is staying on.
PS: You can purchase your own scanner for less than they most likely charge to do one scan. They offered them on this site before. Let me know if you are interested.
SSELANTRA2004
Hi - was traveling on work and didn't get a chance to update until now.
SO, I took the car to another shop - they did a diagnostic chk for FREE. Says the catalytic converter looks ok. Said the prob was most likely the TPS. Advised me to go back and demand it to be fixed.
I took it back (didn't demand or create a scene) but strongly urged them to just get it back to the condition it was in when I brought it to them. So they order an original Hyundai TPS, install it, do a few tests and it is running ok now. Guess it was a cheap part after all.
I mean the original issue exists (sluggish around 2000 rpm) but at least no unexpected racing engine or ragged engine)
So, I guess I got a new fuel filter (whether I needed it or not) and came out from this experience ok.
Plan to take it to the Huundai dealer/shop next week when I have time - closest one is about an hour's drive away - depending on SoCal traffic.
As for all the regulations and "laws" I agree - big time Big Brother. With all the handouts, no wonder they need to tax us more.
Thanks for your help on this.
  • 108,269 POSTS
Well. I glad you got it back to this point. You woldn't believe the junk parts that are being inported into our country. Everything is made so cheaply most likely by slave labor and children. But we just keep sending our jobs anywhere the job can get done cheaper. Something needs done, but what? If a person stands up and says something, he is considered a mad man and put in jail.
Keep in touch with me after the dealer checks it. I'm curious if I was correct.
Take care of yourself.
HEATHERSPARTY
  • 2003 HYUNDAI ELANTRA
2003 Hyundai Elantra 4 cyl Two Wheel Drive Automatic
I have a 2003 hyundai elantra and I dont know whats wrong with it. Every time I start it when its cold, when I put in drive it hestitates. I want to try to replace the fuel filter before I take it in to try major money repairs. But LOL I cant find the fuel filter, and I dont know how to change it. I have a husband, but hes useless too. HELP!
Tuesday, December 31st, 2019 AT 2:02 PM (Merged)
  • 108,269 POSTS
The fuel filter is located near the fuel tank in the rear (under) of the car. It is mounted to the undercarrage of the vehicle. As far as replacing it, the steel fuel lines are bolted into the fuel filter. You will need two wrenches, one to hold the fuel filter still while you turn the nut on the steel fuel line. I believe both sides of the filter come apart like that. After removing the lines, there is a mounting bracket that unbolts and you remove the old filter and reverse the process.
Here is a how to for help:
https://www.2carpros.com/how_to/how_to_change_fuel_filter.htm
NOTE: When you remove the first fuel line, there could still be pressure in it, so be careful and protect yourself and your eyes. Once the pressure is released, you will be fine. Please read the entire How To prior to removing. Also, the picture you will see of the fuel filter is very similar to what you will find under your car.
If you have trouble, let me know.
CEAARM14
  • 2002 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 11,711 MILES
Where is the fuel filter
  • 31,938 POSTS
Hi there,
The filter is under the car next to the fuel tank.
Mark (mhpautos)
RIBICH
  • 2001 HYUNDAI ELANTRA
  • 105,000 MILES
The past few weeks the car hiccupped occassionaly when driving at highway speed (55-60mph)but kept going good. I've put new plugs in, tranny and oil good, air filter good, however, after 5 miles (30-35 mph)(slight grade) it almost stalled (no reaction from gas pedal). After another 5 miles on another grade, it stalled out. I waited a couple minutes and restarted. 10 miles later at highway speed (55-60 mph) it bogged down and came to a stall (no grade, level road). I restarted again and made it another 3 miles to work. Is this the fuel filter or electronic/computer gizmos? I don't feel like tearing out the back seat if it is not the filter/pump.
FIXITMR
  • 9,990 POSTS
When you say hiccup do you mean cuts out completely for a second? Not bogs/slows down?
RIBICH
The hiccup was just a fraction of a second little jolt, a very slight hestation, but kept on rolling.
FIXITMR
  • 9,990 POSTS
Does sorta sound like a fuel problem though. A fuel pressure test could confirm this. And engine sensors also have great influence on fuel delivery even if pressure is right constantly.
RIEBED
  • 111 POSTS
  • 197,000 MILES
Engine not actting up currently but car has 197k on it
  • 108,269 POSTS
It is mounted on the top of the fuel tank. In the fuel pump module
FRANKSTERX
Engine Performance problem
2001 Hyundai Elantra 4 cyl Front Wheel Drive Manual
i would like to know roughly where the fuel filter is located. I thought I looked in the usual places, maybe im over looking it?
BLUELIGHTNIN6
  • 16,542 POSTS
Under vehicle, center, below cargo area, mounted on top of fuel tank, in fuel pump module
SATURNTECH9
  • 30,870 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_2003_hydi_elantra_fuel_filter_1.jpg
The fuel filter is located under the rear seat in a compartment above the fuel tank. Also, a filter sock at the base of the fuel pump located in the fuel tank.
There you go. USER NOTE: Some of the cars don’t have a fuel filter there
