Camshaft timing marks
M K
  • 2001 VOLVO S40
  • 2.0L
  • 4 CYL
  • TURBO
  • FWD
  • MANUAL
  • 225,000 MILES
We replaced the valves on the car listed above it is a T4. I want to know the position of number one and four pistons when the notch on crank shaft lined up between cam shafts. The engine turns nicely, but it does not start. The car has been parked for five months.
please help!
Monday, January 27th, 2014 AT 1:50 AM
HMAC300
  • 48,601 POSTS
Both pistons are at the top of there stroke. Check the timing belt/chain it may be out of time there. Also, piston number should be at TDC when mark on crank is lined up, so it may be on number four. then recheck your work.
https://www.2carpros.com/diagrams/volvo/s40/2001
If its all okay check out this guide for why it wont start.
Please let us know what you find.
Cheers
Monday, January 27th, 2014 AT 7:43 AM
CHVYMAN1
How do you know if the piston is on the exhaust or compression stroke?
Sunday, November 29th, 2015 AT 6:10 PM
SKEET WOMACK
  • 2000 VOLVO S40
  • 1.9L
  • 4 CYL
  • TURBO
  • 150,000 MILES
They are one and the same once the piston is at the top it can be either.
How do I set the timing on the cams after removing the sprockets from the cams? Also, does number one cylinder have to be top dead center to get car in timing?
Replaced the head from a over heat.
Monday, March 27th, 2017 AT 7:03 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,973 POSTS
Yes the engine does need to be on TDC. Here is a diagram that shows the camshaft timing marks.
Please let me know if you need anything else to get the problem fixed.
Best, Ken
SPEEDDEMON155
  • 2000 VOLVO S40
  • 4 CYL
  • 110,000 MILES
How do I line up the exhaust camshaft sproket to the camshaft? I removed the camshaft sproket while taking the valve cover off. There is no lineup pins on the camshaft. I just need to know how to line it up. It is a 2000 Volvo S40 1.9 Turbo.
Thanks!
Monday, March 27th, 2017 AT 7:04 PM (Merged)
ERNEST CLARK
  • 1,730 POSTS
Look on the teeth of the cam sprocket for grooves in the center of the teeth. Then there should be markings on the timing cover. Line these up on both sprockets.
  • 31,937 POSTS
The only way to do this is with a special tool. See picture.
Mark (mhpautos)
SPEEDDEMON155
Thanks for the answers everyone. Mhpautos-after lining up the camshafts on the back do I then turn the exhaust sproket to line up with the front cover?
  • 31,937 POSTS
Problem is I do not know the position of the engine when you dismantled it. You cannot rotate the cams independently of the crank, if you do turn the cam you must do very carefully as to much pressure on a valve touching a piston will cause serious damage. Do you know the relevant cam, crank positions before dis-assembly?
Mark (mhpautos)
RACBOB
  • 0 POST
  • 2002 VOLVO S40
Need the camshaft marking setting that align with the crankshaft.
JDL
  • 16,098 POSTS
This is for 1.9 turbo.
RACBOB
  • 0 POST
  • 2001 VOLVO S40
How to line up the camshafts?
  • 31,937 POSTS
Did the belt brake or was it removed with out first aligning the timing marks? See picture for alignment points. If it broke you will have bent valves.
JBWILLIAM318
  • 1999 VOLVO S40
  • 2.0L
  • 4 CYL
  • TURBO
  • FWD
  • MANUAL
How do you do timing on a volvo s40 t4? The cam pulleys do not have marks.
HMAC300
  • 48,601 POSTS
We do not list a Volvo s40 in US, besides if it is ignition timing the computer does that.
  • 31,937 POSTS
There are special Volvo tools required to do this. See picture for a general view.
Monday, March 27th, 2017 AT 7:05 PM (Merged)
HELPME
  • 2001 VOLVO S40
  • 119 MILES
Want to know which valve opens in the exhaust when its timed, and also want to know which valve opens in the intake when its timed 2001 volvo s40 1.9L. Camshaft, timing
Monday, March 27th, 2017 AT 7:09 PM (Merged)
JIS001
  • 3,408 POSTS
The exhaust valve opens first then the intake. If you need to set up timing you will need buy the cam locking tool to set up the timing.
  • 0 POST
  • 2002 VOLVO S40
Need the align for the camshaft.
JIS001
  • 3,408 POSTS
Here you go, hope information helps you.
https://www.2carpros.com/forum/automotive_pictures/337695_94855773_3.jpg
Monday, March 27th, 2017 AT 7:10 PM (Merged)
