1997 Honda Civic Won't start in extremely cold weather
GRAD2229
  • 1997 HONDA CIVIC
  • 4 CYL
  • 197,000 MILES
When the weather is below zero. My car will not start. Last year I experienced this same problem. When towed to an auto shop. They let it sit inside and it started right away. This year I have added a moisture remover to the fuel and it has worked consistently in low temperatures. However, this morning, it again, has not started. Any thoughts, so I do not have to get a tow every time the temperature drops below zero?
Friday, January 25th, 2008 AT 9:25 AM
MASTERTECHTIM
  • 4,750 POSTS
Did you change the fuel filter? That is where the water will be trapped. I assume your car turns over but wont start.
Friday, January 25th, 2008 AT 9:49 AM
