HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Engine
Symptoms
Oil Leak
1990 Honda Civic oil leak
STEPHENROSSEL
MEMBER
1990 HONDA CIVIC
4 CYL
2WD
MANUAL
47,000 MILES
Just sprung an oil leak at the rear of the engine passenger side, toward the top of the engine. I can't discover the source of the leak.
I also have a 95 Geo Metro 1.0 litre with an oil leak problem at the front of the engine around the pully's.
I hate oil leaks! Any help is appreciated.
Steve
Saturday, February 20th, 2010 AT 12:38 PM
LEGITIMATE007
MECHANIC
The honda's leak is probably at the corner of the valve cover.
Saturday, February 20th, 2010 AT 4:24 PM
LEGITIMATE007
MECHANIC
The geo, is probably at the crankshaft seal
Please
login
or
register
to post a reply.
Related Engine Oil Leak Content
Engine Oil Leak
I Own A 1997 Honda Civic Si With A 1.6l Sohc Vtec. (D16 Engine) The Engine Is Leaking Oil From The Front Of The Engine(same Side As The...
Asked by
chris_SI
1 ANSWER
HONDA CIVIC
GUIDE
Engine Oil Leak
A car engine uses motor oil to lubricate the internal moving parts of the engine such as crankshaft, rod bearings, pistons and valve train. This oil is controlled from...
2009 Honda Civic Engine Oil Leak
Engine Performance Problem 2009 Honda Civic 4 Cyl Two Wheel Drive Automatic 2800km Miles I Bought New Honda Civic 2009 Two Months Ago....
Asked by
vicky khan
1 ANSWER
2009
HONDA CIVIC
1992 Honda Civic Engine Oil Leak
Hello, I Recently Changed The Valve Cover Gasket On My Civic, Because I Thought That Is Where It Was Leaking. The Car Continues To Leak...
Asked by
alexf2937
1 ANSWER
1 IMAGE
1992
HONDA CIVIC
1997 Honda Civic Oil Leak
Trying To Locate Oil Leak. Seems To Be On Top Area Of Engine. Replaced Valve Cover Gasket But That Wasn't The Problem, Apparently, Since...
Asked by
Carbo2
4 IMAGES
1997
HONDA CIVIC
1999 Honda Civic Oil Leak...
Engine Performance Problem 1999 Honda Civic 4 Cyl Two Wheel Drive Manual 133k Miles I Have A 99 Honda Civic Ex Coupe That Leaks Oil. At...
Asked by
checkthemeaning10
1999
HONDA CIVIC
VIEW MORE
Crankshaft Main Seal Replacement - Front
Crankshaft Seal Replacement - Rear
Cylinder Head Gasket Blown Symptoms
