2002 Honda Accord Timing Belt Maintenance
RZAZ1974
  • 2002 HONDA ACCORD
  • 6 CYL
  • FWD
  • 47,324 MILES
I have a 2002 Honda Accord Coupe EX-V6 with 47,000 miles on it. It is my understanding the timing belt should be changed around 100k to 105k miles. The car is running perfect and I am hesistant to get the timing belt changed at the Honda Dealership as it appears that this a complex repair even for a skilled mechanic. Does anyone know the time length for changing the belt? Should I wait another year to get this done? If the belt were to break would it damage the engine?
Do you
have the same problem?
Monday, August 16th, 2010 AT 12:03 PM
KHLOW2008
  • EXPERT
Hi rzaz1974,
The 3.0 is an interference engine and if the timing belt breaks, it is going to damage the engine.
Recommended schedule for timiing belt replacement is 105k miles or 84 months whichever comes first. Get a visual inspection done to verify if the belt condition is still good because at your mileage, it should not be a problem but age of the belt is another matter.
Checking is not difficult, you only need to remove one of the upper cover.
Book time is 4.9 hours with time added if oil seals are to be replaced.
Tuesday, August 17th, 2010 AT 11:46 AM
CWEAVER016
Hi, rzaz1974
I have a 2000 honda accord ex- 3.0 with 140,000 on it. I just recently replace my timing belt at 135,000 and it really didnt need it then. But do a visual inspection on it and see if it needs it. And you only having 45,000 on the car you wont need it for a while. If it does break it can cause serve engine damage. I changed it with help of my friend which is a machinic and it took us 4.5 hours. And cost us about $400. If you take it to a dealer it can cost about $900- $1200. When and if you get this done please change the water pump also most people think its ok but the part is only $80 at the time and you will be right there. Might as well change that out and also the tensioner. If you have any more questions on what exactly we did and how long. Please contace me. Thank you!
Tuesday, August 24th, 2010 AT 9:21 AM
RZAZ1974
Thanks Cweaver016,
That was helpful and leads me to believe the timing belt is very durable since you went 10 years, 135k miles before it was changed.
I called the Honda Dealer Service Department and asked them about a visual inspection of the timing belt. The service tech informed me it would not be cost efficient to do a visual inspection. They claim it would cost $500 for the inspection due to the labor charges. Does that sound accurate? I'd like to get a visual inspection of the timing belt. When I decide it's time to change the belt I would definitely get the water pump changed.
Thursday, August 26th, 2010 AT 8:19 AM
CWEAVER016
Yeah the honda dealers will get all they can off of you in doing it. Its not that hard to do but if you have never worked on cars I would not recommend it. The only reason that the timing belt should need to be replaced sooner is if you driving it to the limits everytime. But if thats not the case it should be fine. Let me know if you have any more questions.
Thursday, August 26th, 2010 AT 8:42 AM
Recommended Guides
