Turn signal flasher location please?
ALONZO39
  • 2005 HONDA ACCORD
  • 4 CYL
  • 129,876 MILES
My right side flasher does not work at all I change the fuse and bulbs
Sunday, January 16th, 2011 AT 8:45 PM
KHLOW2008
  • 41,815 POSTS
You mean nothing happens when right turn signal is used? Does the lights turn on when hazard lights are operated? If not, you have a wiring fault. If they turn on, it could be a bad multi function switch. But the flasher can cause it as well here is the flasher location in the diagrams below. Check out the diagrams (Below). Please let us know what you find.
Sunday, January 16th, 2011 AT 10:13 PM
F4I_GUY
  • 3,302 POSTS
Just to add to KHLow's post. Turn signal relays are very common on your vehicle. It is located just above the underdash fuse block. It's in the top right corner, it's grey in colour.
Sunday, January 16th, 2011 AT 11:15 PM
PAT11
  • 2003 HONDA ACCORD
  • 4 CYL
  • 65,000 MILES
Good day good people, Can you tell me (in layman's term) exactly where the left turn signal flasher is located? MY PROBLEM: The Front and Rear bulbs work the Right flasher work but the Left flasher do not work
Monday, May 17th, 2021 AT 12:11 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi Pat11,
The turn signal flasher relay is located in driver side under dash fuse box. It is item # 4 in diagram.
https://www.2carpros.com/forum/automotive_pictures/192750_FuseDash03AccordFig03_1.jpg
KEITHS
  • 2001 HONDA ACCORD
  • 4 CYL
  • 140,000 MILES
When I changed the bulb in the clock I unplugged the harness for the clock and hazard but when I plugged them back in the turn signals and the hazard lights did not work. I checked the fuses and they were good, what else could it be? All I did was disconnect the two plugs and plug them back in and now the turn signal and hazard lights do not work. Could it be the flasher?
  • 108,244 POSTS
The turn signal flasher is located under the dash on the driver's side of the vehicle. If you look at the attached picture, I highlighted both the flasher and where it goes. Check out the diagrams (Below). Please let us know what you find.
