TDC Sensor
RENEECRUZ
  • 1999 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 222,000 MILES
The TDC sensor is located behind the timing belt covers. You'll have to basically do a timing belt job to replace it, yes the code is P1361, and the other code is P0401, but I know that, that is for the check engine light.
Thursday, November 21st, 2013 AT 12:53 PM
SATURNTECH9
  • 30,869 POSTS
The crankshaft sensor is behind the timing cover down at the crankshaft here are diagrams and instructions on how to change it. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Thursday, November 21st, 2013 AT 1:19 PM
RENEECRUZ
  • 1998 HONDA ACCORD
  • 200,000 MILES
Trying to see where the TDC sensor is located?
Trying to replace the TDC sensor but not sure where its located, can you assist me with this.
Is this difficult to get too? Is this part expense to replace, can I much a used one, will that make a difference?
Tuesday, May 21st, 2019 AT 12:25 PM (Merged)
  • 108,328 POSTS
What is a TDC sensor? TDC stands for "Top Dead Center". Are you referring to the crank sensor?
HONDATECH1983
  • 109 POSTS
The TDC sensor is located behind the timing belt covers. You'll have to basically do a timing belt job to replace it. Why do you think it is bad? Are you getting a trouble code? If so, what code are you getting?
CHAPA
  • 1997 HONDA ACCORD
  • 4 CYL
  • 79,000 MILES
The engine check light on my car came on, the code says its the cranck position sensor ( bad or faulty connection ).
My question is where do I find the connections for this sensor on this car? Can you provide me any info like location and color codes for this wires?
Tank you.
Regards.
MERLIN2021
  • 17,250 POSTS
I don't Have the colors of the wires, but it is located on the lower front part of the engine near the crank pulley. Usually it's a magnetic sensor that reads the exciter on the crank.
BRUCE HUNT
  • 3,753 POSTS
You will need to take off the belts to the crank pulley or harmonic balancer. Then take off the pulley. The bolt comes off much easier with an impact wrench. Then you need to take off the timing belt cover. After going to all this work I would replace the timing belt while I am in there. The sensor is located right next to the crankshaft. It will probably have two sensors on it but they are wired together and replaced as a single unit.
